API DataRecorder.GetSnapshot
GetSnapshot
Gets a block of the output stream with each input sample operated on, returns number of samples read
- HANDLE StreamH
The stream that is to be read
- LONG TimeUS
The time offset to extract the history from, in microseconds
- ULONG TimeStep
The step in microseconds between each sample extracted
- ULONG Samples
The number of samples to extract - this will expand the array
- FLOAT[] Buffer
The buffer to read the sample data into
- ULONG Return
