Exercise - Using Component Macros
This exercise uses them to control a particularly complicated, but very common device, the Liquid Crystal Display (LCD).
In this case, it uses a LCD to display elapsed time.
The core sequence
The flowchart sequence for the elapsed time will be:
- Check if the switch is pressed.
- If it isn't, go back to the beginning.
- If it is:
- initialize the LCD;
- display the text "Elapsed time";
- initialize the time;
- display the time
- wait for one second;
- increment the time;
- display the new time;
- loop back and repeat this process.
Set up the flowchart
- Open Flowcode, and set up the new flowchart as described in Creating Your First Flowchart.
Create the core sequence
- Locate the 'LCD' inside the 'Outputs' toolbox in the Icons toolbar.
- Hover over the image to the left of the 'LCD' label, and click on the down-arrow that appears.
- Click on the 'Add to system panel' option to select it.
- Zoom in until the LCD image is big enough to read.(See System Panel for information on how to zoom.)
- Click and drag an infinite loop between the 'BEGIN' and 'END' icons.
- Inside the loop:
- Click and drag a 'Component macro' icon.
- Double click on it to open the dialogue box, so that you can configure it.
- The program 'knows' which components you have added to the System or Dashboard panel, and modifies the list of available commands accordingly.
