API Panel.Position.RotateAlong
Revision as of 15:35, 10 May 2013 by Admin (talk | contribs) (XML import of API auto-gen)
<sidebar>API contents</sidebar> Rotates the object by the given rotation along an axis
HANDLE Handle
HANDLE Pivot
The coordinates of the rotation center
HANDLE Axis
An axis to align the angles to
FLOAT X_Pitch
The local X degrees to increment by
FLOAT Y_Yaw
The local Y degrees to increment by
FLOAT Z_Roll
The local Z degrees to increment by
  • Add to a calculation icon:
    ::Panel.Position.RotateAlong(handle, pivot, axis, x_pitch, y_yaw, z_roll)
