Exercise - Creating a Flowchart
Revision as of 12:30, 17 July 2013 by ReeceL (talk | contribs)
The task is to produce a Flowcode flowchart that lights a lamp for ten seconds when a switch is pressed.
Although it may not be realistic to use a microcontroller in such a straight-forward application, it illustrates the technique of producing a Flowcode program.
The program itself may form part of a bigger program.
Formulate the sequence
Check if the switch is pressed.
If it isn't, go back to the beginning.
If it is:
switch on the lamp;
wait for 10 seconds;
switch off the lamp;
It takes such a short time for the microcontroller to carry this out, that we don't need to worry whether the switch latches on or not.
Set up the flowchart
The Project Options dialogue box opens.
(Click on the link for a full explanation of all the options available.)
  • Accept the default settings by clicking on 'OK'.
An empty flowchart window opens, which may contain other items such as a System Panel, Dashboard Panel, Properties Panel etc.
These can be revealed or hidden using the View menu.
  • Set up the flowchart window so that you can see the System Panel and the Properties Panel.
The flowchart window should resemble the one shown below (depending on the configuration.)
File:Gen exerciseFirstFlowchart startscreen 01.png
The System Panel and Properties Panel can be moved by clicking and dragging the title bar at the top of each panel.
Set up the input
More information about the icons used in this flowchart can be found in Icon Properties.
  • Drag and drop a 'Loop' icon between the BEGIN and END icons.
The 'Loop' icon will make the microcontroller repeatedly run through the program, (though the icon can be configured to limit the number of times this happens.)
  • Inside the loop, drag and drop an 'Input' icon from the Icons toolbar.
  • This will be configured later to read the state of the switch - to detect if the switch is being pressed.
Check the switch
  • Drag and drop a 'Decision' icon after the 'Input' icon.
This icon will be used to make the program perform what is known as a conditional branch.
When programmed, the icons will currently be able to continually check if the switch is being pressed or not.
In the next step we will be adding icons which will allow us to control what happens if the switch is pressed.
Once the switch is pressed it will perform an the action or process and continue to check if it is being pressed again.
Control the lamp
Next we concentrate on the 'Yes' branch of the 'Decision' icon.
  • Drag and drop an 'Output' icon in the 'Yes' branch.
The effect of this icon is going to trigger the lamp and turn it on.
Next we want the lamp to stay on for ten seconds and then turn off.
  • Drag and drop a 'Delay' icon after the 'Output' icon.
  • This is the icon which will allow us to delay the circuit for a specified period of time.
  • The delay will last for 10 seconds, in this time the circuit will not be able to carry out any other function until the delay is complete.
Finally we need to turn the lamp off, after the ten second delay.
To do this we will need another 'Output' icon.
  • Drag and drop a second 'Output' icon after the 'Delay' icon.
You should now save the flowchart as "Lamp1.fcf", and close Flowcode.
What next
The next step is to add the switch and lamp to the flowchart. This is covered in the exercise Configuring Icons and Variables.
