Examples and Tutorials
Revision as of 08:32, 24 July 2013 by ReeceL (talk | contribs)
This page contains organised exercise used throughout Flowcode Help section, and further exercises which are not featured in the Flowcode Help structure.
Flowcode Help
Creating a Flowchart Preparing and and planning a program by adding icons to a flowchart to be expanded into a program.
Configuring Icons and Variables Configuring the flowchart icons and variables to effective operate a program using components.
Adding Devices to a Program Adding, configuring and manipulating components for suitable and effective use in a program.
Simulating a Program Testing and simulating a program in Flowcode using various methods and techniques of simulation.
Transferring a Program to the Microcontroller Testing and running a program on hardware, compiling to a chip and the process required to do so.
Documenting a Flowchart Using comments to explain and describe your Flowchart and the process of the program.
Expanding a Program Expanding your program further to increase functionality, effectiveness and efficiency.
Using Component Macros Creating and expanding a program by using icons and components, specifically Component Macros.
Using Macros Using Macros and local variables to effectively create and organise a program including components.
Inserting Code Into Flowcode
Using Interrupts Using interrupts, custom interrupts and timers to call macros and configuring interrupt properties.
Debugging Hardware and Software Debugging a program in simulation and on hardware using ICD mode.
Using Analogue Input Devices Creating a program including analogue input devices to drive the system.
Dashboard Panel & System Panel
Adding Objects to the System Panel
Controlling Shapes on the System Panel
Adding Objects to the Dashboard Panel
Controlling Multiple Objects
Controlling Collisions on the System Panel
Component
Create an LED Component
Exporting the LED Component
Importing the LED Component
Testing an Imported Component
Building a Complex Component - the Traffic Cone
Exporting the Traffic Cone
Importing and Testing the Traffic Cone
For further tasks to practice and complete see Labs at the end of the Flowcode Help section
