System Panel
Revision as of 11:20, 6 July 2016 by PaulN (talk | contribs)
<sidebar>Sidebar: Flowcode Help Overview:Panels</sidebar>
The System Panel
Overview
The System Panel is opened by selecting it in the View menu. Unlike the Dashboard Panel, the System Panel is designed to simulate a 3D environment. It is best suited to designing and positioning objects as all aspects of an object can be viewed. Once an object is designed, it is often used in projects via the Dashboard Panel.
When it opens, you see a central coloured square, called the Table top, set against a coloured background. The colours or images of both are set in the 'General Options'.
The System panel has a Controls toolbar running horizontally across the top, much like the Dashboard Panel.
Dashboard or System Panel?
Table top
Axis alignment
Hint:
Manipulating objects
Selecting items
They can then be grouped:
  • By clicking on the 'Group' icon.
Multiple views
A powerful feature of Flowcode 6 is the ability to view the components from several camera angles simultaneously, enabling orthographic design of the system. Up to four views can be shown.
The number of views can be changed by clicking the 'General Options' icon and then clicking on the drop down menu next to the 'Number of views:' option and then selecting a value from 1-4 on the menu.
By clicking on the appropriate arrowheads, you can set up each view as shown below.
Depending on the size and shape of the Systems Panel, the three views may be arranged vertically, instead of horizontally. Drag one edge of the Systems Panel sideways to see this effect.
An example of doing so is given below - notice the positions of the red, green and blue arrows in each:
In the next image, the instrument panel has been rotated:
