| Author
Matrix Ltd
| Version
1.0
| Category
Test Equipment
PicoScope component
A set of functions designed for interacting with a 2000 series Pico scope via simulation.
An example project showing the capabilities of the Velleman K8055D board combined with a Pico Technology series 2 scope.
Velleman and Picoscope Demo
ps2000_get_timebase
| Returns details associated with the selected timebase index
| [[File:]] -
Handle
| the handle of the required device.
| [[File:]] -
timebase
| The ps2000a API allows you to select any of 2 32 different timebases based on a maximum sampling rate of 1 GS/s.
| [[File:]] -
no_of_samples
| number of samples required
| [[File:]] -
time_interval
| time interval between readings at the selected timebase. Use NULL if not required.
| [[File:]] -
time_units
| [[File:]] -
oversample
| not used.
| [[File:]] -
max_samples
| on exit, the maximum number of samples available.
| [[File:]] -
ps2000_open_unit_progress
| This function checks on the progress of a request made to ps2000aOpenUnitAsync to open a scope.
| [[File:]] -
handle
| [[File:]] -
Progress
| [[File:]] -
ps2000_flash_led
| This function flashes the LED on the front of the scope without blocking the calling thread.
| [[File:]] -
handle
| handle of the scope device
| [[File:]] -
ps2000_stop
| This function stops the scope device from sampling data. If this function is called before a trigger event occurs, the oscilloscope may not contain valid data.
| [[File:]] -
Handle
| [[File:]] -
ps2000_get_unit_info
| This function retrieves information about the specified oscilloscope.
| [[File:]] -
Handle
| the handle of the device
- STRING
info_string
| unit information string
| [[File:]] -
string_length
| the maximum number of chars in the string
| [[File:]] -
info_line
| a number specifying what information is required. 0=DriverVersion / 1=USBVersion / 2=HardwareVersion / 3=VariantInfo / 4=BatchAndSerial / 5=CalDate / 6=KernelVersion / 7=DigHardwareVersion / 8=AnHardwareVersion
| [[File:]] -
ps2000_set_channel
| This function specifies whether an input channel is to be enabled, its input coupling type, voltage range, analog offset and bandwidth limit.
| [[File:]] -
handle
| Handle of the device
| [[File:]] -
channel
| the channel to be configured. The values are: 0=ChanA / 1=ChanB
| [[File:]] -
enabled
| whether or not to enable the channel. The values are: 0=Disable / 1=Enable
| [[File:]] -
dc
| the impedance and coupling type. Values: 0=AC / 1=DC
| [[File:]] -
range
| the input voltage range: 0=50mV / 1=100mV / 2=200mV / 3=500mV / 4=1V / 5=2V / 6=5V / 7=10V / 8=20V
| [[File:]] -
ps2000_get_times_and_values
| [[File:]] -
Handle
| [[File:]] -
times
| [[File:]] -
buffer_a
| [[File:]] -
buffer_b
| [[File:]] -
buffer_c
| [[File:]] -
buffer_d
| [[File:]] -
overflow
| [[File:]] -
time_units
| [[File:]] -
no_of_samples
| [[File:]] -
ps2000_set_trigger
| [[File:]] -
handle
| [[File:]] -
source
| [[File:]] -
threshold
| [[File:]] -
direction
| [[File:]] -
delay
| [[File:]] -
auto_trigger_ms
| [[File:]] -
ps2000_set_sig_gen_built_in
| sets up the signal generator to produce a signal from a list of built-in waveforms
| [[File:]] -
Handle
| Handle to the device
| [[File:]] -
Offset_uV
| the voltage offset, in microvolts, to be applied to the waveform
- ULONG
pk2pk_uV
| the peak-to-peak voltage, in microvolts, of the waveform
| [[File:]] -
waveType
| the type of waveform to be generated. 0=Sine / 1=Square / 2=Triangle / 3=RampUp / 4=RampDown / 5=Sinc / 6=Gaus / 7=HalfSine / 8=DC
| [[File:]] -
startFrequency
| the frequency that the signal generator will initially produce
| [[File:]] -
stopFrequency
| the frequency at which the sweep reverses direction or returns to initial
| [[File:]] -
increment
| the amount of frequency increase or decrease in sweep mode
| [[File:]] -
dwellTime
| the time for which the sweep stays at each frequency, in seconds
| [[File:]] -
sweepType
| whether the frequency will sweep from startFrequency to stopFrequency. 0=Up, 1=Down, 2=UpDown, 3=DownUp
- ULONG
sweeps
| produce number of cycles specified by shots
| [[File:]] -
ps2000_close_unit
| This function shuts down an oscilloscope.
| [[File:]] -
Handle
| The handle of the scope device to be closed
| [[File:]] -
ps2000_run_block
| This function starts collecting data in block mode.
| [[File:]] -
handle
| [[File:]] -
no_of_samples
| [[File:]] -
timebase
| [[File:]] -
oversample
| [[File:]] -
time_indisposed_ms
| [[File:]] -
ps2000_get_values
| This function returns block-mode data, with or without downsampling.
| [[File:]] -
Handle
| [[File:]] -
buffer_a
| Start point for data collection
| [[File:]] -
buffer_b
| Number of samples
| [[File:]] -
buffer_c
| Down sample ratio
| [[File:]] -
buffer_d
| Down sample mode : 0=None / 1=Aggregate / 2=Decimate / 4=Average
| [[File:]] -
overflow
| Flags to indicate if an overflow has occurred
| [[File:]] -
no_of_samples
| [[File:]] -
ps2000_ready
| [[File:]] -
Handle
| [[File:]] -
ps2000_open_unit_async
| This function opens a scope without blocking the calling thread.
| [[File:]] -
ps2000_open_unit
| Returns a handle to the opened unit Returns 0 if no unit found Returns -1 if unit failed to open
| [[File:]] -
CommsBaud
| Sets the Baud rate of the alt communications channel
- BYTE
Baud
| Range: 0-7 : 0=1200 / 7=115200
LCDOptions
| Controls some of the LCD options
- BYTE
Foreground
| Range: 0-1
- BYTE
Background
| Range: 0-1
- BYTE
Transparent
| Range: 0-1
LCDVerbose
| Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
- BYTE
Mode
| Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
ReadDigitalInput
| Reads a single digital input.
- BYTE
- BYTE
PWMConfig
| Sets the PWM configuration. Channel = 0 - 1 : 0 = EN_AB, A, B / 1 = EN_CD, C, D Period = 0 - 65535 Scaler = 0 - 3 : 0=1:1 1=1:8 2=1:64 3=1:256
- BYTE
| Range 0-1
- UINT
Period
| Range: 0-65535
- BYTE
Scaler
| Range: 0-3
PWMEnable
| Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE
EnableMask
| Range 0-63 or 0b00000 to 0b111111
PWMDuty
| Sets a single PWM channel duty. Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Duty = 0 - 65535
- BYTE
| Range 0-5
- UINT
Duty
LCDCursor
| Sets the cursor position for the MIAC display
- BYTE
X
| Range: 0-21
- BYTE
Y
| Range: 0-4
WriteTran
| Allows a single transistor output to be switched on or off.
- BYTE
| Range 1-4
- BYTE
Value
| 0 = Off, 1 = On
LCDClear
| Clears the MIAC display
Simulations
