| Author
Matrix TSL
| Version
1.0
| Category
General Input
IO Expander (MCP23017) component
Provides 16 digital input/output pins arranged into two 8-bit ports using a I2C bus connection. Up to eight expanders can be connected to the same I2C peripheral by means of three address pins.
Please click here to download the component source project: FC_Comp_Source_MCP23017.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MCP23017.fcfx
ReadPort
| Reads a value to one of the ports with a mask. Configures the masked bits to be inputs before reading the input value.
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Mask
| Allows port bits to be modified without effecting other bits, 255 = write full port.
- BYTE
ConfigureInversion
| Configures the pin inversion for the two ports. Disabled on all pins by default.
- BYTE
PortA
| Port A inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE
PortB
| Port B inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadPortPin
| Reads a single port pin from one of the ports. Configures the pins to be an input before reading the input value. Returns 0 or 1 corresponding to the value on the port pin.
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Pin
| Port pin to read. Range: 0-7
- BYTE
WritePortPin
| Writes a single port pin on one of the ports. Configures the pins to be an output before writing the input value.
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Pin
- BYTE
Value
| Value to output on the selected pin. Range: 0-1
WritePort
| Writes a value to one of the ports with a mask. Configures the masked bits to be outputs before writing the output value.
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Mask
- BYTE
Value
| Value to write. Range 0-255
ConfigurePullups
| Configures the pullups for the two ports. Disabled on all pins by default.
- BYTE
PortA
| Port A pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE
PortB
| Port B pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadRegister
| Reads an 8-bit value from a register on the I/O expander device.
- BYTE
Address
| Register address to write to. Range: 0-15
- BYTE
SetAddress
| Allows the slave address to be overridden to allow multiple modules to be controlled using a single component.
- BYTE
Address
| Range: 0-7
WriteRegister
| Writes an 8-bit value to a register on the I/O expander device.
- BYTE
Address
- BYTE
Value
| Value to write. Range: 0-255
I²C Communications
External Address
| Selects the value of the three address pins for the MCP23S17.
| Channel selection
Stop Delay
Baud Select
| Baud rate option selector
| Baud rate to be used
SDA
SCL
Use Reset
API
