Loop Icon Properties
<sidebar>Sidebar: Icon Properties</sidebar>
Loop icons are used to repeat a task until specified conditions are fulfilled, or to perform the loop a set number of times.
Note that you will need to add calculation icons that modify the variables used for the condition in order for the condition to be fulfilled.
Display Name
Loop while
Loops the program until the specified condition becomes true. Enter the conditions which will fulfill the loop.
(Setting the test condition to something that is always true will make the loop repeat forever e.g. While 1)
Variables Arrow
Clicking on the down arrow brings up the variables dialog window allowing you to select an existing variable or to create a new one.
Test the loop at the:
Select whether you wish the loop to be tested at the start or at the end of the loop.
Can be set to check the condition at the start of the loop or at the end of the loop.
Loop count
Sets the loop to loop through a set number of times.
Count must be a whole number between 1 and 99999999.
Count using a variable
Allows one of your existing variables to be used as the count variable.
When active this automatically resets the count variable to 0 and increments the variable for you to give you the correct number of loop iterations.
Infinite loops
Sometimes a task needs to be repeated continually. One useful way of achieving this is to have an infinite loop.
Video instructions
See the Loop video to learn how to use infinite, limited and conditional loops, as well as the use of loops with other icons such as Input, Output and Calculation icons.
{{#ev:youtube|Ty0ZfkFbtNQ|640}}
