API DataRecorder.GetSnapshot
Revision as of 11:41, 16 January 2023 by Wiki bot (talk | contribs) (Created page with "{| class="wikitable" style="width:60%; background-color:#FFFFFF;" |- | width="10%" align="center" style="background-color:#D8C9D8;" align="center" | File:Fc9-comp-macro.pn...")
GetSnapshot
Gets a block of the output stream with each input sample operated on, returns number of samples read
- HANDLE StreamH
The stream that is to be read
- LONG TimeUS
The time offset to extract the history from, in microseconds
- ULONG TimeStep
The step in microseconds between each sample extracted
- ULONG Samples
The number of samples to extract - this will expand the array
- FLOAT[] Buffer
The buffer to read the sample data into
- ULONG Return
