API DataRecorder.GetSnapshot
Revision as of 14:07, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "class="wikitable" style="width:60%; background-color:#FFFFFF;"" to "class="mtx-class-macrotable wikitable"")
GetSnapshot
Gets a block of the output stream with each input sample operated on, returns number of samples read
- HANDLE StreamH
The stream that is to be read
- LONG TimeUS
The time offset to extract the history from, in microseconds
- ULONG TimeStep
The step in microseconds between each sample extracted
- ULONG Samples
The number of samples to extract - this will expand the array
- FLOAT[] Buffer
The buffer to read the sample data into
- ULONG Return
