Exercise - Using Component Macros
Revision as of 15:18, 20 June 2013 by JohnVerrill (talk | contribs)
This exercise uses them to control a particularly complicated, but very common device, the Liquid Crystal Display (LCD).
In this case, it uses a LCD to display elapsed time.
The core sequence
The flowchart sequence for the elapsed time will be:
Check if the switch is pressed.
If it isn't, go back to the beginning.
If it is:
initialize the LCD;
display the text "Elapsed time";
initialize the time;
display the time
wait for one second;
increment the time;
display the new time;
loop back and repeat this process.
Set up the flowchart
Create the core sequence
  • Locate the 'LCD' inside the 'Outputs' toolbox in the Icons toolbar.
  • Hover over the image to the left of the 'LCD' label, and click on the down-arrow that appears.
  • Click on the 'Add to system panel' option to select it.
  • Zoom in until the LCD image is big enough to read.(See System Panel for information on how to zoom.)
  • Click and drag an infinite loop between the 'BEGIN' and 'END' icons.
  • Inside the loop:
  • Click and drag a 'Component macro' icon.
  • Double click on it to open the dialogue box, so that you can configure it.
The program 'knows' which components you have added to the System or Dashboard panel, and modifies the list of available commands accordingly.
