Component Properties
Revision as of 15:55, 20 June 2013 by ReeceL (talk | contribs)
<sidebar>Sidebar: Taking Flowcode Further</sidebar> Component properties controls how the component functions and where it is situated on the System Panel or Dashboard Panel, you can directly alter the location of the component using the 'World coordinates' under the 'Position' section of the Properties Panel, you can also manipulate the component by using the 'Scale' section to change the size (and shape) of the component as well as the 'Rotation' section to rotate the component in the panel.
To bring up a components attributes and properties you can right click on a selected component and click 'Properties' which will bring up the 'Properties Panel'. If the Properties Panel is already being displayed simply clicking on the component will bring up the selected component's properties in the panel.
File:Gen LEDarray Properties 01.png
File:Gen Component Context Menu Properties LEDarray.png
The properties for the component can be edited in the Properties Panel by simply clicking the property/attribute value and/or typing in a value (depending on the component and property).
Extra help for that specific component can be found by searching for the component on this wiki.
File:Gen LEDarray Properties Connections 02.png
