Exercise - Using Component Macros
Revision as of 17:07, 20 June 2013 by JohnVerrill (talk | contribs)
This exercise uses them to control a particularly complicated, but very common device, the Liquid Crystal Display (LCD).
In this case, it uses a LCD to display elapsed time.
The core sequence
The flowchart sequence for the elapsed time will be:
Check if the switch is pressed.
If it isn't, go back to the beginning.
If it is:
initialize the LCD;
display the text "Elapsed time";
initialize the time;
display the time
wait for one second;
increment the time;
display the new time;
loop back and repeat this process.
Set up the flowchart
Create the core sequence
  • Locate the 'LCD' inside the 'Outputs' toolbox in the Icons toolbar.
  • Hover over the image to the left of the 'LCD' label, and click on the down-arrow that appears.
  • Click on the 'Add to system panel' option to select it.
  • Zoom in until the LCD image is big enough to read.(See System Panel for information on how to zoom.)
  • Click and drag an infinite loop between the 'BEGIN' and 'END' icons.
File:Gen exerciseUsingCompMacros compmacprops 01.png
Initialise the LCD
  • Inside the loop:
  • Click and drag a 'Component macro' icon.
  • Double click on it to open the dialogue box, so that you can configure it.
The program 'knows' which components you have added to the System or Dashboard panel, and modifies the list of available commands accordingly.
Under 'Components', the LCD will be listed, and underneath it the list of commands.
  • Scroll down to the bottom of the list and click on the 'Start' command.
  • Rename the 'Display name' as "Start the LCD".
  • Click on 'OK'.
  • The dialogue box resembles that shown opposite.
File:Gen exerciseUsingCompMacros compmacprops2 01.png
Set up the display
  • Click and drag a second 'Component macro' icon just below the first.
  • Double click on it to open the dialogue box.
  • Scroll down to the 'PrintString' command and click on it.
  • Rename the 'Display name' as "Elapsed time".
  • In the 'Expression' box, type "Elapsed time" (making sure you include the quotation marks "".)
  • Click on 'OK'.
  • The dialogue box is shown opposite.
File:Gen exerciseUsingCompMacros timevarprops 01.png
Display elapsed time
  • In the 'Edit' menu, on the main toolbar, click on 'Variables...' to open the 'Variable Manager' dialogue box.
  • Hover just to the left of the 'Variables' label, and click on the down arrow that appears.
  • Select 'Add new' and the 'Create a New Variable' dialogue box opens.
  • Name the new variable "time", and give it an initial value of zero.
  • Leave the variable type as 'Byte'.
  • Click on 'OK'.
  • The dialogue box should resemble that opposite.
File:Gen exerciseUsingCompMacros compmacroprops3 01.png
  • Click and drag a third component macro to follow the second one.
  • Scroll down to the 'PrintNumber' command and click on it.
  • Rename the 'Display name' as "Display elapsed time".
  • In the 'Expression' box, type the variable name "time".
  • Click on 'OK'.
  • The third 'Component Macro' dialogue box is shown opposite.
