Exercise - Using Component Macros
This exercise uses them to control a particularly complicated, but very common device, the Liquid Crystal Display (LCD).
In this case, it uses a LCD to display elapsed time in a timer.
The core sequence
At the core of the program is a section that sets up the LCD to display the time.
The flowchart sequence for displaying the elapsed time will be:
- Initialize the LCD.
- Display the text "Elapsed time".
- Set the time to zero.
- Display the time.
- Wait one second.
- Increment the time.
- Display the new time.
- Loop back and repeat the process from the delay again.
Set up the flowchart
- Open Flowcode, and set up the new flowchart as described in Creating Your First Flowchart.
Create the core sequence
Add the LCD
- Locate the 'LCD' inside the 'Outputs' toolbox in the Icons toolbar.
- Hover over the image to the left of the 'LCD' label, and click on the down-arrow that appears.
- Click on the 'Add to system panel' option to select it.
- Zoom in until the LCD image is big enough to read.(See System Panel for information on how to zoom.)
Initialise the LCD
- Click and drag an infinite loop between the 'BEGIN' and 'END' icons.
- Inside the loop:
- Double click on it to open the dialogue box, so that you can configure it.
- The program 'knows' which components you have added to the System or Dashboard panel, and modifies the list of available commands accordingly.
- Under 'Components', the LCD will be listed, and underneath it the list of commands.
- Scroll down to the bottom of the list and click on the 'Start' command.
- Rename the 'Display name' as "Start the LCD".
- Click on 'OK'.
- The dialogue box resembles that shown opposite.
Set up the display
- Click and drag a second 'Component macro' icon just below the first.
- Double click on it to open the dialogue box.
- Scroll down to the 'PrintString' command and click on it.
- Rename the 'Display name' as "Elapsed time".
- In the 'Expression' box, type "Elapsed time" (making sure you include the quotation marks "".)
- Click on 'OK'.
- The dialogue box is shown opposite.
Display elapsed time
- In the 'Edit' menu, on the main toolbar, click on 'Variables...' to open the Variable Manager dialogue box.
- Hover just to the left of the 'Variables' label, and click on the down arrow that appears.
- Select 'Add new' and the 'Create a New Variable' dialogue box opens.
- Name the new variable "time", and give it an initial value of zero.
- Leave the variable type as 'Byte'.
- Click on 'OK'.
- The dialogue box should resemble that opposite.
- Click and drag a third 'Component Macro' to follow the second one.
- Scroll down to the 'PrintNumber' command and click on it.
- Rename the 'Display name' as "Display elapsed time".
- In the 'Expression' box, type the variable name "time".
- Click on 'OK'.
- The third 'Component Macro' dialogue box is shown opposite.
- Click and drag a 'Delay' icon to follow the third 'Component Macro'.
- Rename it "Wait one second."
- Configure it to give a delay of one second.
- For help with 'Delay' icons, see Icon Properties
- Click on 'OK'.
- Click and drag a 'Calculation' icon to follow the 'Delay'.
- Rename it "Add one second."
- In the 'Calculations:' section, type "time=time+1".
- The effect of this is to increase the number stored in the 'time' variable by one, (also called incrementing the 'time' variable.)
- For help with 'Calculation' icons, see Icon Properties
- Click on 'OK'.
Test the Core
- The diagram below shows the flowchart at this stage.
- At this point, the flowchart should be saved as 'Stopwatch', and can be simulated to test it.
Add the switch
- Locate the 'Push Round Panel' switch in the 'Inputs' toolbox in the Icons toolbar.
- Hover over the image to the left of the switch label, and click on the down-arrow that appears.
- Click on the image of the switch on the System panel to select it and drag it to a suitable position.
- On the Panel Properties, click on the 'Unconnected' label, next to 'Connection'.
- A pinout of the microcontroller appears.
- Click on the rectangle that represents the pin RB0/INT, to connect the switch to Port B, bit 0 of the microcontroller.
