System Panel
Overview
When it opens, you see a central coloured square, called the Table top, set against a coloured background. The colours or images of both are set in the General Options.
Table top
Camera control
- Camera controls
- Hold down the Ctrl key and click-drag the mouse to move the camera eye.
- Hold down both the Ctrl and Shift keys and click-drag the mouse to move the camera target.
- Hold down Alt and click anywhere on the panel to move the camera over that point or object.
Zoom
Axis alignment
Hint:
Selecting items
They can then be grouped:
Shapes toolbar
Under the 2D section there is a 'Text' icon, used to 'drag and drop' a single row of alphanumeric characters onto the work area. Afterwards, you can select it, by clicking on it, and configure it using the Properties Panel. In particular, when added, you can edit the default text displayed using the bottom ‘Text’ control on the Properties panel. As well as text, there are also a few two-dimensional shapes available, such as; Ellipse (circle), Rectangle, Rounded Rectangle and finally a Line.
Controls toolbar
Moving objects
The left-hand end control allows you to move the selected object around the work area.
Moving to the right, the next control allows you to re-position a single point on an item. When you select an object and click on this control, pink anchors appear on the object. Selecting one of these allows it to be moved to a new position on the work area. The effect is to change the appearance, size or rotation of the object.
File:Gen Panel Object Resize 01.png The next control allows you to change the size of the object. After selecting an object and clicking on this control, a number of blue anchors appear on the object. Any of these can be dragged to re-size that particular dimension of the object. (Handles at the corners affect size in two dimensions.)
Controlling the camera
The first allows the camera to pan left / right / up / down.
The second allows the camera to rotate assuming the table top is the ground.
The third allows the camera to rotate without considering the table top.
General Options
The next control determines what happens when two objects ‘collide‘. The options are that they move through, move around or move over each other, with respect to the camera view.
The next control is used to align the camera with the selected object.
The first allows you to lock movement of objects:
- To the grid,
- To other objects,
- To the table-top
The second general options dialog is used to:
Multiple views
By selecting multiple views in the 'General Options' several camera angles can be displayed on the same image, enabling orthographic design of the system. Up to four views can be shown.
