Ribbon Toolbar
Revision as of 09:58, 27 August 2013 by ReeceL (talk | contribs)
<sidebar>Sidebar: Getting Started</sidebar> The Flowcode environment consists of a main work area in which the flowchart windows are displayed, several toolbars that allow icon and components to be added to the flowchart application, windows that allow the status of the microcontroller and attached components to be viewed and windows that display variables and macro calls when the flow chart is being simulated.
From the View menu you are able to customise Flowcode to hide and display panel windows such as the Dashboard Panel, System Panel, Properties Panel, Component Debugger and much more, you can also show / hide the Toolbars referenced as Toolboxes, e.g. the 'Main Toolbar', 'Components Toolbar' or rather Toolbox, as well as the 'Icons Toolbar' otherwise known as the 'Command Toolbox'
Video instructions
See the Accessing and Arranging Flowcode Panels video to learn how to organise the application to your preference and manage your workspace effectively.
See the Toolbars and Buttons video to learn what the toolbar buttons do and how to use them.
FXa7LJsRvAs}} 9c6FIZTfGmA}}
1) Icons Toolbar
2) Components Toolbar
This toolbar displays the external components that can be connected to a microcontroller. Click on a component and it can be added onto either the Dashboard Panel or the System Panel and will be automatically connected to the microcontroller in the Chip view. The pin connections and properties of the component can then be edited.
Docking and undocking toolbars
Chip / Microcontroller View
4) Flowchart Window
System Panel
Dashboard Panel
Project Explorer
Icon Lists Pane
10) Main Toolbar
Use this command to display and hide the Toolbar, which includes buttons for some of the most common commands in Flowcode, such as 'Open' (File > Open), 'Print' (File > Print) as well as Compiling the flowchart to Chip, HEX and C. You can even control simulation by running, pausing and stopping simulation using this toolbar as stepping into and over icons to simulate step by step.
11) Status Bar
