API Panel.Position.RotateAlong
<sidebar>API contents</sidebar> Rotates the object by the given rotation along an axis
===Class hierarchy===Panel
HANDLE Handle
HANDLE Pivot
- The coordinates of the rotation center
HANDLE Axis
- An axis to align the angles to
FLOAT X_Pitch
- The local X degrees to increment by
FLOAT Y_Yaw
- The local Y degrees to increment by
FLOAT Z_Roll
- The local Z degrees to increment by
- Add to a calculation icon:
::Panel.Position.RotateAlong(handle, pivot, axis, x_pitch, y_yaw, z_roll)
