Component: Sheep Pen (Scenarios)
Revision as of 14:51, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Version 1.0 (Release)
Category Scenarios
Image Sheep Pen component
A simple sheep pen simulation with two gates and two sensors. Allows for simple logical control to try and move all the sheep from one pen to another.
Sheep Pen Scenario
This component does not contain any downloadable macros
Simulation macro reference
ReadSensor
Checks to see if an object is on the Sensor.
Returns 0 if nothing is on the Sensor, Returns 1 if an object is on the Sensor.
This macro has no parameters
BOOL : Returns true if the operation is a success, else false
ControlGateB
Allows gate B to be opened and closed.
BOOL State
0 = Closed, 1 = Open
ControlGateA
Allows gate A to be opened and closed.
BOOL State
Inactive Sensor
This property is of type Color picker and can be referenced with the variable name ColA.
Active Sensor
This property is of type Color picker and can be referenced with the variable name ColB.
Num Objects
This property is of type Fixed list of ints and can be referenced with the variable name NumObjects.
Specifies the number of objects active in the simulation.
