Component: DALI Master (Comms: System)
Revision as of 20:38, 9 February 2022 by MartinW (talk | contribs) (Examples)
Author MatrixTSL
Category Comms: System
DALI Master component
A serial based communications protocol designed for controlling lighting, specifically digitally controlled dimmable fluorescent ballasts. DALI requires the signals to be level shifted from VCC and GND to +9.5V - +25.5V and GND. The master component can addess up to 64 individual slaves & up to 16 groups.
COMMSC
DALI Master Example, reads the value of a keypad and sends out DALI commands based on the key pressed, 1 = switch on a slave's light, 2 = switch off a slave's light, 3 = read the slave's light level. DALI Master Example1
For a DALI Slave example see: Component: DALI Slave (Comms: System)
ReceiveBackwardFrame
Attempts to receive an 8-bit reply 0 indicates timeout or no reply
TransmitForwardFrame
Send out a 16-bit frame consisting of the 8-bit address and data bytes. After sending the controller will attempt to receive If a reply is detected then the Return value will equal to the reply. If no reply is detected then the Return value will be 0.
- BYTE Address
Address byte
- BYTE Data
Data Byte
TransmitIndividualForwardFrame
Sends out an individual frame containing address and data. After sending the controller will attempt to receive a reply. If a reply is detected then the Return value will equal to the reply. If no reply is detected then the Return value will be 0.
- BYTE Address
Individual Address 0-63
- BYTE Type
0 = Data, 1 = Command
- BYTE Data
TransmitGroupForwardFrame
Sends out a group frame containing address and data. After sending the controller will attempt to receive a reply. If a reply is detected then the Return value will equal to the reply. If no reply is detected then the Return value will be 0.
- BYTE Address
Group Address 0-15
- BYTE Type
- BYTE Data
Configures the UART serial interface.
TX Pin
RX Pin
Simulations
API
