Component: Potentiometer (Trimmer) Free ()
Revision as of 17:53, 9 November 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.4 |- | width="20%" style="color:gray...")
Version 1.4
Category
Potentiometer (Trimmer) Free component
Trim Pot for 0.1mm pitch PCB. With finger dial knob. Pointer colour can be changed from component properties.
Please click here for the component source code: FC_Comp_Source_knob_trim_finger_free.fcfx
Start Angle
Sweep Angle
Color
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
