Component: DALI Master (Comms: System)
| Author | MatrixTSL |
| Category | Comms: System |
DALI Master component
A serial based communications protocol designed for controlling lighting, specifically digitally controlled dimmable fluorescent ballasts. DALI requires the signals to be level shifted from VCC and GND to +9.5V - +25.5V and GND. The master component can addess up to 64 individual slaves & up to 16 groups.
Please click here to view the component source code (Beta): FC_Comp_Source_DALI_Master.fcfx
DALI Master Example, reads the value of a keypad and sends out DALI commands based on the key pressed, 1 = switch on a slave's light, 2 = switch off a slave's light, 3 = read the slave's light level.
 DALI Master Example1
For a DALI Slave example see: Component: DALI Slave (Comms: System)
|   | ReceiveBackwardFrame |
| Attempts to receive an 8-bit reply 0 indicates timeout or no reply | |
|  - BYTE | Return |
|   | Initialise |
| Configures the UART serial interface. | |
|  - VOID | Return |
|   | Properties |
|   | Serial Properties |
|   | TX Pin |
|   | RX Pin |
|   | Simulation |
|   | API |
|  - BYTE | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | Serial Properties |
|   | TX Pin |
|   | RX Pin |
|   | Simulation |
|   | API |
