| Author
Matrix TSL
| Version
1.0
| Category
Analog Input
ADC QUAD + DAC (PCF8591) component
An I2C device allowing for up to 4 x 8-bit analogue inputs as well as 1 x 8-bit analogue output. Up to 8 devices can be used together ona signel I2C bus.
Please click here to download the component source project: FC_Comp_Source_External_ADC4_DAC1_PCF8591.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_External_ADC4_DAC1_PCF8591.fcfx
EnableDAC
| Enables and Disables the DAC output, Default Disabled.
- BOOL
Enabled
| 0=Disabled, 1=Enabled
WriteDAC
| Writes a value to the digital to analogue output.
- BYTE
Value
SetupADC
| Configures how the ADC inputs are wired
- BYTE
Configuration
| Range: 0-3, Default 0
SampleADC
| Performs a single ADC sample on the selected ADC channel
- BYTE
| Range: 0-3
- BYTE
| Sets up the I2C bus ready for communications with the device.
Device Address
| The address pins are used to allow up to 8 individual devices to be connected onto an I2C bus. Sets the state of the pins.
| Channel selection
SDA
SCL
Stop Delay
Baud Select
| Baud rate option selector
| Baud rate to be used
Simulate Comms
| Allows the communications to be simulated overriding the value on the panel slider controls.
EnableDAC
- BOOL
Enabled
WriteDAC
- BYTE
Value
SetupADC
- BYTE
Configuration
SampleADC
- BYTE
| Range: 0-3
- BYTE
Device Address
| Channel selection
SDA
SCL
Stop Delay
Baud Select
Simulate Comms
EnableDAC
- BOOL
Enabled
WriteDAC
- BYTE
Value
SetupADC
- BYTE
Configuration
SampleADC
- BYTE
| Range: 0-3
- BYTE
Device Address
| Channel selection
SDA
SCL
Stop Delay
Baud Select
Simulate Comms
EnableDAC
- BOOL
Enabled
WriteDAC
- BYTE
Value
SetupADC
- BYTE
Configuration
SampleADC
- BYTE
| Range: 0-3
- BYTE
Device Address
| Channel selection
SDA
SCL
Stop Delay
Baud Select
Simulate Comms
