Component: Photo Transistor (Light)
Revision as of 11:51, 3 February 2023 by Wiki bot (talk | contribs)
Category Light
Photo Transistor component
Uses InfraRed light to detect if an external object is near to the sensor. Returns a digital signal which can represent detected or not detected states. Useful for applications like line following, punched card based data systems and robotics.
Please click here to download the component source project: FC_Comp_Source_PhotoTransistor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_PhotoTransistor.fcfx
A basic example which moves an object on the panel. When the object is in range of the sensor the sensor output goes high, otherwise the sensor output goes low. PhotoTransistorDemo
SampleSensor
SampleSensor
Samples the sensor and automatically controls the emitter pin if enabled. Returns the state of the sensor pin.
Configures the I/O ready for the sensor to be sampled.
Emitter Type
Decides if the emitter needs to be switched on and off during sampling
Sense Pin
Pin connected to the sensor element of the photo transistor
Sensor Range
Simulation range used to determine if the sense pin is active or not.
