Component: ADC QUAD + DAC (PCF8591) (Analog Input)
Revision as of 12:19, 3 February 2023 by Wiki bot (talk | contribs)
Category Analog Input
ADC QUAD + DAC (PCF8591) component
An I2C device allowing for up to 4 x 8-bit analogue inputs as well as 1 x 8-bit analogue output. Up to 8 devices can be used together ona signel I2C bus.
Please click here to download the component source project: FC_Comp_Source_temp/External_ADC4_DAC1_PCF8591.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/External_ADC4_DAC1_PCF8591.fcfx
EnableDAC
Fc9-comp-macro.png EnableDAC
Enables and Disables the DAC output, Default Disabled.
Fc9-bool-icon.png - BOOL Enabled
0=Disabled, 1=Enabled
Fc9-comp-macro.png Initialise
Sets up the I2C bus ready for communications with the device.
SampleADC
Fc9-comp-macro.png SampleADC
Performs a single ADC sample on the selected ADC channel
Range: 0-3
SetupADC
Fc9-comp-macro.png SetupADC
Configures how the ADC inputs are wired
Fc9-u8-icon.png - BYTE Configuration
Range: 0-3, Default 0
WriteDAC
Fc9-comp-macro.png WriteDAC
Writes a value to the digital to analogue output.
Fc9-u8-icon.png - BYTE Value
Fc9-type-16-icon.png Device Address
The address pins are used to allow up to 8 individual devices to be connected onto an I2C bus. Sets the state of the pins.
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Simulation
Allows the communications to be simulated overriding the value on the panel slider controls.
