Component: MQTT Client (Comms: IoT/Cloud)
| Version | 1.1 |
| Category | Comms: IoT/Cloud |
MQTT Client component
A component providing access to MQTT IoT client. The client can connect to a MQTT server such as ThingSpeak. Allowing IoT type data to be published and read back.
Please click here to download the component source project: FC_Comp_Source_temp/MQTT_Client.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/MQTT_Client.fcfx
The MQTT component requires connection to a Network Comms component via the "Network Component" property, to provide the bridge for simulated TCP/IP communication.
The Network Comms component can then be linked to an embedded TCP/IP component to provide embedded TCP/IP support.
Here is a typical setup for using MQTT on a Raspberry Pi.
Local Weather
A simple example demonstrating how to use MQTT with Flowcode SCADA to get the local weather conditions.
The example shows temperatures from Halifax in the UK and from Sydney in Australia.
Publish
Raspberry Pi
Here we have an embedded Raspberry Pi project connected to an I2C Sensor, the sensor is sampled and the data is published to a MQTT server.
ESP8266 Module
Here we have an embedded project using an ESP8266 wifi module, an analogue input is sampled and the data is published to a MQTT server.
Subscribe
ESP8266 Module
Here we subscribe to a topic and receive it back into Flowcode embedded using an ESP8266 module.
Flowcode App Developer
Here we subscribe to a topic and receive it back into Flowcode App Developer.
Making your own Raspberry Pi based MQTT Broker
Click here for instructions on creating your own Raspberry Pi MQTT Broker.
Connect
| Connect | |
| Connect to the MQTT Server. Returns the connected state. 0 if not connected, 1 if successful connection, or already connected. | |
Disconnect
| Disconnect | |
| Disconnects from the MQTT server and the network | |
ErrorAsString
| ErrorAsString | |
| Error | |
GetPayload
| GetPayload | |
| Get the Payload of the last received (Read) packet. Returns the number of bytes for the Payload | |
| Payload | |
| Size | |
| Byte count the Payload buffer | |
GetTopic
| GetTopic | |
| Get the Topic of the last received (Read) packet. Returns the number of bytes for the Topic | |
| Topic | |
| Size | |
| Byte count the Topic buffer | |
LastError
| LastError | |
| Returns the last error | |
Ping
| Ping | |
| Ping packet is sent to the Server and checks for a reply. Returns non-zero value if successful | |
Publish
| Publish | |
| Publish data to the server (broker) Returns non-zero if successful | |
| Topic | |
| Payload | |
Read
| Read | |
| Read incoming data. Returns non-zero if packet received. Use GetTopic and GetPayload to read the contents. | |
Subscribe
| Subscribe | |
| Subscribe to a Topic. Must be Connected first Returns non-zero if successful | |
| Topic | |
Unsubscribe
| Unsubscribe | |
| Unsubscribe from a Topic. Must be Connected first Returns non-zero if successful | |
| Topic | |
