Examples and Tutorials
This page provides resources for users to get started with Flowcode. It includes guides for microcontrollers, web development, PC applications, and using APIs to control Arduino and ESP32.
There are examples for Raspberry Pi, Sysblocks for signal processing, and embedded systems like heat control and power monitoring. Tutorials for touch and graphical displays are also available.
The page includes App Developer projects, such as web-based communication and MQTT integration, along with real-world scenarios like traffic lights and CNC machines.
It’s a comprehensive resource for Flowcode users across multiple platforms.
Beginner Examples= ==ESP32=
These ESP32 Flowcode example projects provide a hands-on introduction to working with various sensors, displays, and control mechanisms using the ESP32 platform.
From testing motor functionality to interacting with I2C components and creating simple flashing patterns, these examples are ideal for beginners looking to explore embedded systems development with ESP32.
These will also work with Matrix's EBlocks ESP32 Programmer.
Flasher - ESP
This example creates a basic flashing LED pattern, controlled by the ESP32.
Flasher - ESP
Counter - ESP
A simple counter program that increments values based on input signals using the ESP32.
Counter - ESP
Potentiometer ESP
This example shows how to read analog values from a potentiometer and display them on the ESP32.
Potentiometer ESP
Macros ESP
Learn how to create and use macros to simplify repetitive tasks in Flowcode projects with ESP32.
Macros ESP
LCDs ESP
This example explores how to control and display information on an LCD using the ESP32.
LCDs ESP
Motor Test - ESP32
This project tests motor control functionality using the ESP32 as the controller.
motor test - ESP32
Grove I2C temp and hum ESP
This program shows how to read temperature and humidity data from a Grove I2C sensor with the ESP32.
Grove I2C quad 7-seg ESP
This example demonstrates how to interface with a Grove I2C quad 7-segment display using the ESP32.
PIC
These PIC16F18877 Flowcode example projects provide a hands-on introduction to working with various sensors, displays, and control mechanisms using the PIC16F18877 platform.
From testing motor functionality to interacting with I2C components and creating simple flashing patterns, these examples are ideal for beginners looking to explore embedded systems development with PIC microcontrollers.
These will also work with Matrix's EBlocks PIC Programmer.
Flasher - PIC
This example creates a basic flashing LED pattern, controlled by a PIC microcontroller.
Flasher - PIC
Counter - PIC
A simple counter program that increments values based on input signals using a PIC microcontroller.
Counter - PIC
Potentiometer PIC
This example shows how to read analog values from a potentiometer and display them on a PIC microcontroller.
Potentiometer PIC
Macros PIC
Learn how to create and use macros to simplify repetitive tasks in Flowcode projects with a PIC microcontroller.
Macros PIC
LCDs PIC
This example explores how to control and display information on an LCD using a PIC microcontroller.
LCDs PIC
Motor Test - PIC
This project tests motor control functionality using a PIC microcontroller as the controller.
motor test - PIC
Grove I2C temp and hum PIC
This program shows how to read temperature and humidity data from a Grove I2C sensor with a PIC microcontroller.
Grove I2C quad 7-seg PIC
This example demonstrates how to interface with a Grove I2C quad 7-segment display using a PIC microcontroller.
Arduino
Arduino Uno
These Arduino Uno Flowcode example projects provide a hands-on introduction to working with various sensors, motors, and control mechanisms using the Arduino Uno platform.
From controlling DC motors to interacting with I2C components and creating flashing patterns, these examples are perfect for beginners looking to explore embedded systems development with the Arduino Uno.
These will also work with Matrix's EBlocks Arduino Programmer.
Flasher - Uno
This example creates a basic flashing LED pattern, controlled by the Arduino Uno.
Flasher - Uno
Counter - Uno
A simple counter program that increments values based on input signals using the Arduino Uno.
Counter - Uno
Potentiometer Uno
This example shows how to read analog values from a potentiometer and display them on the Arduino Uno.
Potentiometer Uno
Macros Uno
Learn how to create and use macros to simplify repetitive tasks in Flowcode projects with the Arduino Uno.
Macros Uno
LCDs Uno
This example explores how to control and display information on an LCD using the Arduino Uno.
LCDs Uno
DC motor test - Uno
This project tests DC motor control functionality using the Arduino Uno.
DC motor test - Uno
Grove Temperature Humidity Sensor - Uno
This program shows how to read temperature and humidity data from a Grove sensor with the Arduino Uno.
Grove temp hum sensor - Uno
Grove I2C quad 7-seg - Uno
This example demonstrates how to interface with a Grove I2C quad 7-segment display using the Arduino Uno.
Introduction to Microcontrollers Course
We recommend going through the Flowcode section of the https://www.flowcode.co.uk/resources/datasheets/Microcontroller%20compete%20course.pdf course.
Embedded Getting Started Guide
The Embedded Getting Started Guide introduces you to the Flowcode environment and take you though to programming a microcontroller.
Web Developer getting started
New with the release of Flowcode v10.1 is Web Developer which allows the development of interactive web pages using the Flowcode IDE environment on any platform that supports HTML browsers.
The Web Developer Getting Started Guide takes you through your first experience of Web Developer and demonstrates how to generate interactive HTML files.
PC Developer Getting Started Guide
The PC Developer Getting Started Guide takes you through the various stages of creating PC developer code that includes switches, timer and graph logging.
Using PC_Developer APIs to Control an Arduino
The Using PC Developer APIs to Control an Arduino Takes you through creating HMI (Human machine Interface) Windows-based applications. that can control ESP32, and Arduino hardware in real time.
Raspberry Pi_Getting Started Guide
The Raspberry Pi Getting Started Guide shows you how to set up the Raspberry Pi to enable it to be programmed via Flowcode.
Sysblocks Getting Started Guide
The Sysblocks Getting Started Guide take you through signal processing for Music Technology, DSP, Communications and Software Defined Radio.
Sysblocks is an exciting piece of hardware for use with education in mind.
There are loads of examples available. To find an example of a component you are interested in. Search for the component by selecting the magnifying glass on the left Components Libraries ribbon. Right-click on the component you would like to look at an example for, then select help. If there are no examples available then you can request an example on the forums.
Embedded
Heat Control - Coarse
Many modern electronic systems include some form of simple closed loop heat control to function. Some examples include a kitchen oven, a microwave oven, an iron, hair straighteners, electric heater, etc.
These devices typically work by monitoring the temperature and then switching on a heating element when the temperature is less then the required temperature. The element is then switched off again when the required temperature is reached.
The electronics involved could be a microcontroller digital output pin connected to a simple transistor, diode and relay to control the heater element and a thermistor to measure the heat.
Heat Control - Fine
More advanced electronic systems may require a bit more fine control of the temperature to avoid overshoot and improve response to load changes. Some examples include a SMD reflow oven, 3D printer hotend, soldering iron, etc.
These devices typically work by monitoring the temperature and then providing an analogue output to a heating element. The analogue value is calculated using a transfer function in this case we are using PID control.
The electronics involved could be a microcontroller PWM output pin connected to logic level FET or TRIAC to control the heater element and a thermocouple to measure the heat.
Multi-function AC Power Monitor
The PZEM-004T is Multifunction AC Power Monitor which uses MODBUS to communicate with the microcontroller.
It can measure Voltage, Current, Frequency Power, Power Factor & Energy used (Resettable).
The power level threshold can be set to give OVERPOWER warning.
Before programming, check LCD address and Power Level Threshold are correct within the 2D Panel Properties.
As the MODBUS uses UART channel on the Arduino Uno, the UART software timer is used to send all the power values. Therefore you will require a TTL to USB converter or an analyser that can decode UART.
Arduino Uno AC Multi-function Monitor v1.2
Current Sensor (ACS7xx) component
ACS7XX range of unidirectional and bidirectional 5, 20, 30, 50, 100, 150 & 200A current sensors
A simple example shows how to use a ASC712 component to measure a current range of +/- 5A. The component type can be changed within its properties.
Circular Buffer - Reliable Communications Data
This example takes bytes received from the Serial UART and uses the circular buffer to store the bytes as they come in using an interrupt. The main routine then forwards the bytes through to a PC using a USB serial connection.
This example would work equally well for creating a bridge between several UARTs or translating Serial to SPI or I2C etc.
UART to USB Serial Data Bridge
The LCD will retain the contents of the display, for high speed data we only want to have to write to the portion of the display that can change.
BME280 Barometer plus Altitude v1.0
This example reads and displays the pressure, temperature & humidity.
If the pressure is increasing then Rise will be displayed.
Programming Touch and Graphical Displays
These programs are used in the Youtube video Touch and graphical displays parts 1 and 2
gLCD Demo for SPI HGY 480 x 320 Display
gLCD Demo for Cap Touch Display on Rowland Technology PCB
Image for Test_card_6_for_Rowland
Images for Test_card_7_for_HGY_480_320
Menu system example for a gLCD
Images for Menu system example
M5stack dial
M5stack demo shows you how you can develop a simple test card for the M5 stack dial using Flowcode
M5stack demo shows you how you can make an electronic safe project for the M5stack Dial
Place the bitmap file in the same folder as the project file for the simulation to work.
App Developer
A range of example App Developer projects are available from here: https://www.flowcode.co.uk/app-developer/free-apps/
A basic worked example showing how to use Flowcode to create an embedded project that is controlled via a web app using HTTP.
This set of 6 projects provides a detailed look at simple communications between an ESP32 device and a web browser using Flowcode to construct both the embedded app and the web app.
HTTP Comms Worked Example - Web Developer
A worked example showing how to create an embedded project that communicates with a PC via the serial port.
This simple example shows two projects - an embedded app and a PC-based app - that communicate with each other using the serial port, exchanging text messages between the embedded device and the PC.
Serial Comms Worked Example - PC Developer
A worked example showing how to develop Flowcode MQTT apps.
This project details a simple application for exchanging messages between embedded and non-embedded devices using the popular MQTT protocol. Flowcode is used to create three apps - an embedded app running on an ESP32 device, a PC app running on Windows and a web app running in a browser.
MQTT Worked Example - Web & PC Developer
Scenarios
This page contains a list of the scenarios included with Flowcode.
The corresponding components can be found in the Runtime section of the component toolbar.
