Component: MQTT Client (Comms: IoT/Cloud)
Revision as of 08:59, 9 June 2025 by Wiki bot (talk | contribs)
Version 1.1
Category Comms: IoT/Cloud
MQTT Client component
A component providing access to MQTT IoT client. The client can connect to a MQTT server such as ThingSpeak. Allowing IoT type data to be published and read back.
Version information
7, 1.1, 23-07-24, BR, Added Max Packet Size property to allow the size of a single packet to be altered by the user
8, 1.1, 30-07-24, BR, Resolved ESP compile error due to missing return and added TopicTooLong error
The MQTT component requires connection to a Network Comms component via the "Network Component" property, to provide the bridge for simulated TCP/IP communication.
The Network Comms component can then be linked to an embedded TCP/IP component to provide embedded TCP/IP support.
Here is a typical setup for using MQTT on a Raspberry Pi.
Local Weather
A simple example demonstrating how to use MQTT with Flowcode SCADA to get the local weather conditions.
The example shows temperatures from Halifax in the UK and from Sydney in Australia.
FC6 Icon.png SCADA BBC TEMPERATURES
Publish
Raspberry Pi
Here we have an embedded Raspberry Pi project connected to an I2C Sensor, the sensor is sampled and the data is published to a MQTT server.
FC6 Icon.png RPI3 MQTT IOT EBM016
ESP8266 Module
Here we have an embedded project using an ESP8266 wifi module, an analogue input is sampled and the data is published to a MQTT server.
FC6 Icon.png MQTT IOT ESP8266
Subscribe
ESP8266 Module
Here we subscribe to a topic and receive it back into Flowcode embedded using an ESP8266 module.
FC6 Icon.png Subscribe ESP8266 MQTT
Flowcode App Developer
Here we subscribe to a topic and receive it back into Flowcode App Developer.
FC6 Icon.png Subscribe App Developer MQTT
Making your own Raspberry Pi based MQTT Broker
Click here for instructions on creating your own Raspberry Pi MQTT Broker.
Connect
Fc9-comp-macro.png Connect
Connect to the MQTT Server. Returns the connected state. 0 if not connected, 1 if successful connection, or already connected.
ConnectTo
Fc9-comp-macro.png ConnectTo
Connect to a variable MQTT Server, overriding the Host and Port properties. Returns the connected state. 0 if not connected, 1 if successful connection, or already connected.
Fc9-string-icon.png - STRING Host
Fc9-u16-icon.png - UINT Port
Fc9-string-icon.png - STRING ClientID
Client identifier name - must be unique on server
Disconnect
Fc9-comp-macro.png Disconnect
Disconnects from the MQTT server and the network
ErrorAsString
Fc9-comp-macro.png ErrorAsString
Fc9-u8-icon.png - BYTE Error
GetPayload
Fc9-comp-macro.png GetPayload
Get the Payload of the last received (Read) packet. Returns the number of bytes for the Payload
Fc9-string-icon.png - STRING Payload
Fc9-u8-icon.png - BYTE Size
Byte count the Payload buffer
GetTopic
Fc9-comp-macro.png GetTopic
Get the Topic of the last received (Read) packet. Returns the number of bytes for the Topic
Fc9-string-icon.png - STRING Topic
Byte count the Topic buffer
Fc9-comp-macro.png Initialise
LastError
Fc9-comp-macro.png LastError
Returns the last error
Ping
Fc9-comp-macro.png Ping
Ping packet is sent to the Server and checks for a reply. Returns non-zero value if successful
Publish
Fc9-comp-macro.png Publish
Publish data to the server (broker) Returns non-zero if successful
Read
Fc9-comp-macro.png Read
Read incoming data. Returns non-zero if packet received. Use GetTopic and GetPayload to read the contents.
Subscribe
Fc9-comp-macro.png Subscribe
Subscribe to a Topic. Must be Connected first Returns non-zero if successful
Unsubscribe
Fc9-comp-macro.png Unsubscribe
Unsubscribe from a Topic. Must be Connected first Returns non-zero if successful
Fc9-type-16-icon.png LinkTo
Fc9-type-10-icon.png Host
Address of MQTT Broker Can be an IP Address or URL (URL only supported by some hardware platforms)
Fc9-type-21-icon.png Port
Port used by MQTT Broker Default 1883 for unencrypted access and 8883 for encrypted access.
Fc9-type-10-icon.png Client identifier
Client identifier (Maximum length 20 characters) Must be unique to the broker.
Fc9-type-21-icon.png Network Timeout
Maximum time in mS to wait for network responses
Fc9-type-21-icon.png Read Timeout
Amount of time in ms to wait for incoming messages.
Fc9-type-21-icon.png Keep Alive
The Keep Alive is the maximum time interval that is permitted to elapse between the point at which the Client finishes transmitting one Control Packet and the point it starts sending the next, measured in seconds.
Fc9-type-16-icon.png Authentication
Selects if the broker is open or if the broker requires a username and password.
Fc9-type-21-icon.png Max Packet Size
Sets the number of bytes that can be sent and received in a single packet. A single packet consists of 4 header bytes, plus the topic and payload string data.
Please click here to download the component source project: FC_Comp_Source_MQTT_Client.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MQTT_Client.fcfx
