Component: COM Port (Runtime Tools)
| Author | Matrix Ltd |
| Version | 103.11 |
| Category | Runtime Tools |
- 1 COM Port component
- 2 Version information
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 ClosePort
- 5.2 ConfigureConsole
- 5.3 GetConsoleHandle
- 5.4 GetProp
- 5.5 OpenPort
- 5.6 ReceiveBinary16Bit
- 5.7 ReceiveBinary32Bit
- 5.8 ReceiveBinaryFloat
- 5.9 ReceiveByte
- 5.10 ReceiveByteArray
- 5.11 ReceiveFloat
- 5.12 ReceiveHexNumber
- 5.13 ReceiveINTArray
- 5.14 ReceiveNumber
- 5.15 ReceiveString
- 5.16 ReceiveStringWithTermination
- 5.17 ScanForDeviceID
- 5.18 ScanForDeviceIDEx
- 5.19 SendBinary16Bit
- 5.20 SendBinary32Bit
- 5.21 SendBinaryFloat
- 5.22 SendByte
- 5.23 SendByteArray
- 5.24 SendFloat
- 5.25 SendHexNumber
- 5.26 SendINTArray
- 5.27 SendNumber
- 5.28 SendString
- 5.29 SetDTRState
- 5.30 SetFlowControl
- 5.31 SetProp
- 6 Property reference
- 7 Component Source Code
COM Port component
Serial based simulation component for use with systems such as RS232, Bluetooth and USB Serial.
Version information
Library Version, Component Version, Date, Author, Info 10, 103.10, 07-04-25, MW, Modified ReceiveArray NumValues from Byte to UInt 11, 103.11, 01-05-25, BR, Changed SendString macro to make it more efficient
ClosePort
| ClosePort | |
| Closes the currently open COM port, ending communications and allowing it to be accessed via another application. | |
ConfigureConsole
| ConfigureConsole | |
| Status | |
GetConsoleHandle
| GetConsoleHandle | |
| Gets the handle to the console allowing data displaying on the panel etc. | |
GetProp
| GetProp | |
| Allows the property filter for the COM port list to be copied to a parent component. | |
| PropName | |
OpenPort
| OpenPort | |
| Opens the currently selected COM port, allowing data to be sent and received. | |
ReceiveBinary16Bit
ReceiveBinary32Bit
ReceiveBinaryFloat
ReceiveByte
| ReceiveByte | |
| Attempts to receive a byte using the COM port No valid return data is provided by the timeout value property. | |
| Timeout | |
| Time to wait for incoming data in milliseconds | |
ReceiveByteArray
ReceiveFloat
ReceiveHexNumber
ReceiveINTArray
ReceiveNumber
ReceiveString
ScanForDeviceID
| ScanForDeviceID | |
| Checks to see if a device VID/PID string is present and returns the COM port number. Returns 0 if device not found. | |
| HWID | |
| Example: "VID_12BF&PID_0101" | |
ScanForDeviceIDEx
SendBinary16Bit
| SendBinary16Bit | |
| Sends out a 16-bit binary value split across two bytes. | |
| Value | |
| MSBfirst | |
| 0=Least significant byte first, 1=Most significant byte first | |
SendBinary32Bit
| SendBinary32Bit | |
| Sends out a 32-bit binary value split across four bytes. | |
| Value | |
| MSBfirst | |
SendBinaryFloat
| SendBinaryFloat | |
| Sends out a 32-bit binary floating point value split across four bytes. | |
| Value | |
| MSBfirst | |
SendByte
| SendByte | |
| Sends a single byte to be sent out via the COM port. | |
| Data | |
SendByteArray
| SendByteArray | |
| Sends an array of bytes to the COM port. | |
| Data | |
| Data byte array to send | |
| Length | |
| Number of bytes to send | |
SendFloat
| SendFloat | |
| Sends out a floating point number as an ASCII String from the UART interface. | |
| Number | |
SendHexNumber
SendINTArray
SendNumber
| SendNumber | |
| Sends out a number as an ASCII String from the UART interface. | |
| Number | |
SendString
| SendString | |
| Sends an string of characters to the COM port. | |
| Data | |
SetDTRState
| SetDTRState | |
| Allows the DTR signal to be enabled or disabled. | |
| State | |
| A value of 0 disables the DTR, 1 or above willl enable the DTR. | |
SetFlowControl
| SetFlowControl | |
| Allows the Flowcontrol signals to be enabled or disabled. | |
| State | |
| A value of 0 disables flow control, 1 or above willl enable flow control. | |
SetProp
| SetProp | |
| Allows the COM port property to be set from a parent component. | |
| PropName | |
| PropVal | |
Please click here to download the component source project: FC_Comp_Source_COM_Port_1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_COM_Port_1.fcfx
