Exercise - Importing the LED Component
Revision as of 11:20, 24 May 2013 by JohnVerrill (talk | contribs) (Created page with " * Create a new flowchart. * Open the 'Outputs' toolbox, where we stored the exported 'newLED' component. (If no destination was specified for the exported component, it woul...")
  • Create a new flowchart.
  • Open the 'Outputs' toolbox, where we stored the exported 'newLED' component. (If no destination was specified for the exported component, it would appear in the 'Misc' toolbox.)
  • Locate the 'newLED' component, and use the down-arrow next to it to add it to the System Panel. It can now be used in the same way as any other electronic device.
  • Create a flowchart which uses the imported component.
Create a LED component as shown in the Exercise - Create a LED component.
Setting the category
Select category Description and other details
Declaring the interface
  • Move the mouse cursor over the System Panel, and right-click.
  • Configure this for the LED component. In particular, click on the 'Interface' tab, and set the 'LEDoff' and 'LEDon' macros as 'Component' macros. The 'PinChange' macro is a 'Hidden' macro.
  • Click on 'OK'.
Saving the component
  • You may be asked if you want to save the current flowchart. Do so if you wish.
  • The 'Save As' dialogue box opens. This will automatically point to a destination Flowcode will search for components. Select a suitable name for the component.
  • Click 'Save'. The component file is saved with a '*.fcpx' extension.
Testing the component
Select to create a new flowchart from the main menu.
Go to the category your component was assigned to be in. If you did not select a category you will find the component inMisc.
Drag your component onto a panel, or double click on it.
Create a test flowchart
