Exercise - System Panel - Adding Objects
Revision as of 16:04, 28 May 2013 by JohnVerrill (talk | contribs)
This exercise sets up the System Panel, loaded with ..... and ..... . Although specific settings are given, you should play around with alternatives to see the effect.
  • Open a new Flowcode flowchart.
  • Make sure that the System Panel is visible. If necessary, click on View and then on the check-box next to 'System Panel'.
Make the following changes:
  • Move the 'Level of detail' slider fully to the right (to '10').
  • Select 'Table top' shadow mode.
  • Choose a 'Background' style of 'Solid color' and set the background color to dark blue, (Red=0, Green=0, Blue=128 on the 'Custom' tab.)
  • Set the 'Table top' size to '20'.
  • Choose a 'Table top' style of 'Solid color' and set its color to light blue, (Red=0, Green=70, Blue=255 on the 'Custom' tab.)
  • Set it to snap to the 'Table top', by clicking on the check-box next to the 'Table top' label.
  • Leave the 'Show' gridlines box unchecked.
