Component: MIAC NXT AllCode API (AllCode)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 1.1
Category AllCode
MIAC NXT AllCode API component
Controls the MIAC NXT hardware loaded with the MIAC NXT AllCode firmware. Usefull for SCADA, Control or Test applications. Compatible with USB / Bluetooth / Wifi / Ethernet
Please click here to download the component source project: FC_Comp_Source_MIAC_NXT_AllCode_Component_Source.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_MIAC_NXT_AllCode_Component_Source.fcsx
DisplayClear
DisplayClear
Clears the MIAC display
DisplayCursor
DisplayCursor
Sets the cursor position for the MIAC display
- BYTE X
Range: 0-21
- BYTE Y
Range: 0-3
DisplayFloat
DisplayFloat
Prints a floating point number to the MIAC display starting from the current cursor position.
- FLOAT Value
Range: Float
- BYTE NumDP
Number of decimal places to display
DisplayNumber
DisplayNumber
Prints a number to the MIAC display starting from the current cursor position.
- LONG Value
Range: Signed Long
DisplayPixel
DisplayPixel
Controls a single pixel on the MIAC display
- BYTE X
Range: 0-119
- BYTE Y
Range: 0-31
- BOOL State
Range: 0-1
DisplayPrint
DisplayPrint
Prints a string to the MIAC display starting from the current cursor position.
- STRING data
Range: 0-21
GetAPIVersion
GetAPIVersion
Gets the API version of the MIAC NXT AllCode Firmware. Useful to see if the MIAC NXT is responding to commands.
ReadAnalogInput
ReadAnalogInput
Reads a single analog input with range 0 to 4095 corresponding to input voltage 0V to +V.
- BYTE Channel
Range: 1 - 8
ReadDigitalInput
ReadDigitalInput
Reads a single digital input.
- BYTE Channel
Range: 1 - 8
ReadDigitalInputs
ReadDigitalInputs
Reads all digital inputs at once and returns as a binary value. Input 1 = Bit 0 Input 8 = Bit 7
ReadKey
ReadKey
Reads a keypress from the keypad. Returns 0 for no keypress or 1-9 for a valid keypress. 1 = TopLeft, 2=TopMiddle, 3=TopRight, 4=CenterLeft etc
SetAPIVerbose
SetAPIVerbose
Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
- BOOL Mode
Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
WriteRelay
WriteRelay
Allows a single relay to be switched on or off.
- BYTE Channel
Range 1-2
- BOOL Value
0 = Off, 1 = On
WriteRelays
WriteRelays
Allows all relays to be switched on or off in a single command.
- BYTE Value
Range: 0-3 or 0b00 to 0b11
WriteTran
WriteTran
Allows a single transistor output to be switched on or off.
- BYTE Channel
Range 1-6 where 1=A / 2=B / 3=C / 4=D / 5=E / 6=F
- BOOL Value
0 = Off, 1 = On
WriteTranPWMDuty
WriteTranPWMDuty
Sets the PWM duty on the selected channel.
- BYTE Channel
Range: 1-4 Where 1=A / 2=B / 3=C / 4=D
- BOOL EnableOrState
1 = Enable / 0 = State
- UINT Duty
WriteTranPWMEnable
WriteTranPWMEnable
Allows pulse width modulated transistor outputs to be switched on or off.
- BYTE Channel
PWM on Enable Pin or State Pin - 1 = Enable / 0 = State
- BOOL OnOrOff
1 = Enabled / 0 = Disabled
WriteTrans
WriteTrans
Allows all transistor outputs to be switched on or off in a single command.
- BYTE Value
Range: 0-63 or 0b000000 to 0b111111
API Connection Type
API connection mode. COM - Bluetooth / RS232 / RS485 WIFI - Network
Warnings On Error
Generates a warning dialogue if the communication to the device fails allowing the program to be ended.
Connection Properties
Auto Detect
