Component: Formula AllCode (RB4420) (Robotics)
Revision as of 12:17, 6 August 2026 by BenR (talk | contribs) (→Simulation with the API component)
Version 1.3
Category Robotics
Formula AllCode component
A component to allow all the features of the Formula AllCode robot to be investigated. Fully simulated component which can interact with simulated objects on the panel as well as control the real hardware.
Line Following
Line following example using the Formula AllCode, works with objects on the simulation panel and on the real hardware.
FA-Line
An example showing how to use the API component to drive the robot in simulation.
FA API Sim Demo
AudioAddToBuffer
AudioAddToBuffer
Writes a value to the 16-bit audio output buffer.
- UINT Data
AudioQueueLength
AudioQueueLength
Retreives the current length of valid data within the audio queue
AudioReadFromBuffer
AudioReadFromBuffer
Allows the audio buffer to be used for other streaming data such as recording the mic.
AudioStreamControl
AudioStreamControl
Allows control of the audio output functionality via the onboard speaker. Data is loaded into the audio output buffer using the AddToBuffer function.
- BYTE Mode
0=Off, 8=8-bit Mode, 16=16-bit Mode
- BYTE SampleRate
Sets the sample rate 0=8KHz, 1=16KHz
BluetoothCheckConnection
Checks the status of the Bluetooth connection. Returns 0 for not paired and 1 for paired.
BluetoothQueueLength
Reads the length of received Bluetooth data in bytes.
BluetoothReceive
BluetoothReceive
Attempt to read a byte from the Bluetooth receive queue.
BluetoothTransmit
BluetoothTransmit
Sends a byte via the Bluetooth data connection.
- BYTE Data
BluetoothTransmitString
Sends a string via the Bluetooth data connection.
- STRING Data
CheckIR
CheckIR
Checks to see if a IR sensor is within the master threshold distance. Returns 0 if the IR reading is below the threshold. Returns 1 if the IR reading is greater than or equal to the threshold.
- BYTE Sensor
Range: 0 to 7 - 0=Left, 1=Front Left, 2=Front, 3=Front Right, 4=Right, 5=Rear Right, 6=Rear, 7=Rear Left
CheckLine
CheckLine
Checks to see if a line sensor is within the master threshold distance. Returns 0 if the IR reading is below the threshold. Returns 1 if the IR reading is greater than or equal to the threshold.
- BYTE Sensor
Range: 0 to 1 - 0=Left, 1=Right
CheckUSB
CheckUSB
Checks to see if a USB cable is connected to the robot. Returns 0 for no connection and 1 for an active connection.
EncoderReadCount
EncoderReadCount
Reads one of the motor encoder counters. Each encoder count is equal to 0.314159 mm.
- BYTE Channel
0 = LeftCount, 1=RightCount
EncoderReset
EncoderReset
Resets the encoder counters to 0
Forward
Forward
Drives both motors of the formula flowcode forwards with the power specified.
- BYTE Power
Amount of power to use to drive motor. Range 0-100
Starts up the Formula Allcode PWM for motor control and performs the wait for button press if enabled.
LCDBacklight
LCDBacklight
Controls the brighness of the LCD backlight
- BYTE Brightness
Range: 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
LCDClear
LCDClear
Clears the contents of the graphical LCD.
LCDDrawLine
LCDDrawLine
Draws a line on the LCD.
- BYTE X1
Range 0-127
- BYTE Y1
Range 0-31
- BYTE X2
Range 0-127
- BYTE Y2
Range 0-31
LCDDrawRectangle
LCDDrawRectangle
Draws a rectange on the LCD.
- BYTE X1
Range 0-127
- BYTE Y1
Range 0-31
- BYTE X2
Range 0-127
- BYTE Y2
Range 0-31
- BYTE Transparent
Sets the transparency of the box, 0=Box contains background colour, 1=Box contains previous pixel data
- BYTE Solid
Chooses to fill the box with colour, 0=Box contains transparency data, 1=Box contains foreground colour
LCDPlotPixel
LCDPlotPixel
Allows a single pixel on the LCD to be set or cleared.
- BYTE X
Sets the X coordinate - Range 0-127
- BYTE Y
Sets the Y coordinate - Range 0-31
LCDPrintNumber
LCDPrintNumber
Prints a numeric value to the graphical LCD.
- BYTE X
The horizontal start pixel. Range 0-127
- BYTE Y
Y coordinate to print the string. Range 0-31
- INT Number
- BYTE Transparent
LCDPrintString
LCDPrintString
Prints a string to the graphical LCD.
- BYTE X
- BYTE Y
- STRING Data
- UINT Transparent
LCDSetBackgroundColour
Sets the pixel colour to drive the LCD. Default colour is 1 where a set pixel is black and the background is white.
- BYTE Colour
Range 0-1 : 0=White, 1=Black
LCDSetForegroundColour
- BYTE Colour
LCDWriteByte
LCDWriteByte
- BYTE Data
- BYTE X
- BYTE Y
LEDOff
LEDOff
Switches off a single LED on the front of the Formula Allcode.
- BYTE LED
Which LED to switch on, range 0-7
LEDOn
LEDOn
Switches on a single LED on the front of the Formula Allcode.
- BYTE LED
LEDWrite
LEDWrite
Allows control of all 8-LEDs on the front of the Formula Allcode.
- BYTE LED_Byte
8-bit binary value to write to the 8 LEDs
LogoBackwards
LogoBackwards
Drives the robot backward using the encoders as feedback to ensure the robot drives straight. Automatically stops at the specified distance.
- UINT Distance
Distance you want to robot to drive in mm. Range 1-65535
LogoCalibrateMotors
LogoCalibrateMotors
Runs a short forward and reverse test, measures encoder balance, and saves motor trim values to EEPROM for this robot.
LogoConfigure
LogoConfigure
The Logo movement may sometimes be slightly off in terms of distance or angle. Before tweaking the factory values check that the wheels are pushed well onto their shafts but not tight against the FA body. Also check the tyre is on the wheel correctly.
- FLOAT Distance
mm per encoder step. default = 0.32
- FLOAT Angle
mm of travel per degree. default = 0.7295
LogoForwards
LogoForwards
Drives the robot forward using the encoders as feedback to ensure the robot drives straight. Automatically stops at the specified distance.
- UINT Distance
LogoSetSpeed
LogoSetSpeed
Sets the cruise speed for LOGO type macros. Default speed 20%.
- BYTE Speed
Range 1-100, Default 60
LogoTurnLeft
LogoTurnLeft
Rotates the robot left by a specific angle using the encoders as feedback to ensure the robot turns evenly. Automatically stops at the specified turn angle.
- UINT Angle
Angle in degrees you wish to rotate. Range 1-65536
LogoTurnRight
LogoTurnRight
Rotates the robot right by a specific angle using the encoders as feedback to ensure the robot turns evenly. Automatically stops at the specified turn angle.
- UINT Angle
PlayNote
PlayNote
Outputs a single tone from the onboard speaker for the period specified.
- UINT Note
Sets the pitch of the note in Hz. Range: 1 - 10000
- UINT Time
Time period to play the note for in milliseconds. Range: 0 - 65535 ms
ReadBattery
ReadBattery
Reads the current voltage level from the LiPo battery. Return value is the battery voltage in Volts. Take care not to run the battery too low. Voltages lower than 3.4V may damage the battery.
- FLOAT Return
ReadIRSensor
ReadIRSensor
Reads the analogue value from the specified IR distance sensor. Return value range: 0 to 4095 4095 represents the object is very close.
- BYTE Channel
ReadLDR
ReadLDR
Reads the current light level from the on board light sensor. Return value range: 0 to 4095 4095 represents the maximum level of light and 0 represents the minimal level of light.
ReadLineSensor
ReadLineSensor
Reads the analogue value from the specified IR line sensor. Return value range: 0 to 4095 4095 represents the object is reflecting the most light.
- BYTE Channel
ReadMic
ReadMic
Reads the current audio signal level from the on-board microphone. Return value range: 0 to 4095
ReadSwitch
ReadSwitch
Reads the value of one of the switches from the front of the Formula Allcode.
- BYTE Switch
Which switch do we want to read 0=Left, 1=Right
Reverse
Reverse
Drives both motors of the formula flowcode backwards with the power specified.
- BYTE Power
SetMotors
SetMotors
Sets the speed and direction of the Formula Allcode motors.
- INT Left
Valid Range = -100 to 100
- INT Right
SpinLeft
SpinLeft
Spins the formula flowcode on the spot in an anticlockwise direction as seen from above.
- BYTE Power
SpinRight
SpinRight
Spins the formula flowcode on the spot in a clockwise direction as seen from above.
- BYTE Power
Stop
Stop
Stops both motors.
WaitForSwitch
WaitForSwitch
Waits for the specified switch to be pressed.
- BYTE Switch
Which switch do we want to wait for 0=Left, 1=Right, 2=Either, 3=Both
Wait For Button
Determines if the program will automatically wait for one of the front switches to be pressed before executing the program. Ran as part of the initialise function after the various components have been initialised.
Show Creation Info
Specifies what information is shown to the user on calling the initialise function. The time and date shown are the compilation time and date to help pinpoint the firmware version.
Bluetooth Reset
Decides if the Bluetooth data connection can reset the Formula AllCode. Used by mLoader when programming via Bluetooth to allow reprogramming without having to physically touch the robot. To ensure programming security set this option to No.
Turn Scale
Scales turn distance. Lower if turns go too far (try 0.85). Raise if turns stop short (try 0.95). Default 0.88.
Reverse Scale
Scales backward distance. Lower if backward goes too far. Default 1.0 (adjust after brake fix if needed).
Forward Scale
Scales forward distance. Lower if forward goes too far (try 0.96). Default 1.0.
Use Motor Feedback
Controls when the motor feedback is used. No - Speed control feedback is not used for SetMotors commands. Yes - Speed control feedback is used for the SetMotors commands. SetMotors commands include Forward, Backward, SpinLeft, SpinRight as well as SetMotors itself. Logo functions always use feedback.
IR Simulation
IR Simulation Mode
Controls how the IR sensors are modelled in simulation. Linear is the legacy mode and works as it has always done. Exponential attempts to provide a more accurate reading which is closed to response of the real world hardware,
IR Thresholds (CheckIR macro)
IR Distance
IR Threshold used with the CheckIR macro
Line Sensitivity
Simulation Properties
Sim Speed (1 - 100)
Sets the simulated amount of movement relative to the speed of the Formula Allcode.
Timer Interval (ms)
Interval in milliseconds between each simulated movement of the Formula Allcode robot.
Collision Method
Select which objects the robot sensors will interact with.
Light Source
Panel object specified as the simulation light source. Used when simulating "find the light" type tasks.
Addon Mechanics
Useful if you are creating add-ons to the robot which you want to be able to simulate. Point the property at the group containing the Formula Allcode and the additional mechanics. Otherwise leave blank to maintain the normal simulation functionality.
Please click here to download the component source project: FC_Comp_Source_FA_Source_P4.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_FA_Source_P4.fcfx
