Exercise - Creating a Flowchart
Revision as of 12:08, 11 June 2013 by JohnVerrill (talk | contribs)
The task is to produce a Flowcode flowchart that lights a lamp for ten seconds when a switch is pressed.
Although it may not be realistic to use a microcontroller in such a straight-forward application, it illustrates the technique of producing a Flowcode program.
The program itself may form part of a bigger program.
Check if the switch is pressed.
If it isn't, go back to the beginning.
If it is:
Switch on the lamp.
Wait for 10 seconds.
Switch off the lamp.
Go back to the beginning.
File:Gen Running Flowcode Startup Selection.png
It takes such a short time for the microcontroller to carry this out, that we don't need to worry whether the switch latches on or not.
  • Open Flowcode.
  • On the Startup screen, click on 'New embedded project'. (See Opening Flowcode
File:Project Options Target 16F1937.png
The Project Options dialogue box opens.
(Click on the link for a full explanation of all the options available.)
  • Accept the default settings by clicking on 'OK'.
An empty flowchart window opens, which may contain other items such as a System Panel, Dashboard Panel, Properties Panel etc.
These can be revealed or hidden using the View menu.
  • Set up the flowchart window so that you can see the System Panel and the Properties Panel.
The flowchart window should resemble the one shown below (depending on the configuration.)
File:Gen exerciseFirstFlowchart startscreen 01.png
The System Panel and Properties Panel can be moved by 'clicking and dragging the title bar at the top of each panel.
  • Drag and drop a 'Loop' icon between the Begin and End icons.
The 'Loop' icon makes the microcontroller repeatedly run through the program, (though the icon can be configured to limit the number of times this happens.)
File:Gen exerciseFirstFlowchart newvar 01.png
  • Inside the loop, drag and drop an 'Input' icon from the Icons toolbar,. (See Tools and Views.)
  • Double click on the icon.
This opens the 'Properties: Input' dialogue box, allowing you to configure the way the program treats information from the switch.
This information will be contained in a variable called 'switch'.
  • Click on the down arrow at the right-hand end of the 'Variable:' box to open the variables dialogue box.
  • Hover to the left of the 'Variables' label and click on the down arrow that appears.
  • Click on the 'Add new' option to open the 'Create a New Variable' dialogue box.
  • Create a new variable named "switch" with initial value "0" and description "Copies the state of the switch"
  • Leave the 'Variable type:' as 'Byte'.
(For more information about variables, see Creating Variables and Variable Types.
(The resulting dialogue box is shown opposite.)
This will
