Exercise - Adding Devices to a Program
This exercise assumes that you have already built the Flowcode flowchart described in the exercise Creating a Flowchart.
To complete the program, you need to add the two electronic components, the switch and the lamp.
Load the Flowcode Flowchart
- Open the flowchart, called 'Lamp1.fcf' which you created in the exercise Creating a Flowchart.
- (For help with this, see the exercise Opening an Existing Flowchart)
- The System Panel and Panel Properties should be visible. If not, use the View menu to select them.
Add the Switch
- Click on the 'Inputs' toolbox, and locate the 'Push Round Panel' switch.
- Hover over the image, and click on the down arrow that appears.
- Select the 'Add to system panel' option.
- Click on the switch on the System Panel to select it. Its properties appear in the Panel Properties.
- Notice that the name ('Handle') of the component selected appears at the top of the Panel Properties.
- In this case, it shows the name of the switch as 'sw_push_rnd_pnl'!
- Find the 'Connections' properties on the Panel Properties, and click on the 'Unconnected' label.
- A pinout of the microcontroller appears.
- Click on the rectangle representing the pin for Port A bit 0 (called RA0/AN0 on the graphic.)
- This connects the switch to Port A bit 0 of the microcontroller, matching the settings you used when you created the flowchart.
- This setting is shown opposite.
- No other properties need changing, though 'Scale' allows you to change the size (and shape) of the switch if you wish.
Add the Lamp
- Click on the 'Outputs' toolbox, and locate the 'Single LED', which we will use as a lamp..
- The LED appears in the middle of the System Panel, probably right on top of the switch.
- It should already be selected, but if not click on it.
- If so, drag it to a suitable position off to one side.
- With the LED selected, look at the Panel Properties.
- Notice that the 'Handle' has changed to 'led'.
- The 'Connection' property shows that it is already connected to Port A, bit 0.
- This has to be changed, as the flowchart expects it to be connected to Port B, bit 0.
- Click on the label $PORTA,0 and, as before, a pinout of the chip appears.
- Click on the rectangle representing the pin for bit 0 of Port B, shown as RB0/INT.
- The Panel Properties now show that the LED is connected to Port B, bit 0.
- Once again, no other properties need changing, though 'Scale' and 'Bulb color' settings can be altered to change the size and color of the LED.
Save the Flowchart
- For more information, see Saving a Flowchart.
What Next?
Now that the flowchart is complete, we are ready to test it. The exercise Simulating a Program deals with this.
