System Panel
The System Panel
Overview
When it opens, you see a central coloured square, called the Table top, set against a coloured background. The colours or images of both are set in the General Options. File:Panel Icon GeneralOpts.jpg
Table top
Camera control
  • Hold down the Ctrl key and click-drag the mouse to move the camera eye.
  • Hold down both the Ctrl and Shift keys and click-drag the mouse to move the camera target.
  • Hold down Alt and click anywhere on the panel to move the camera over that point or object.
Zoom
File:Panel Icon Zoom.jpg There is also a zoom facility, operated by pressing the Ctrl key and moving the cursor over the viewpoint icon. Clicking the mouse button in this and dragging downwards causes the view to zoom out. Dragging upwards causes the view to zoom in. The same functionality can be achieved by holding Ctrl and using the mouse wheel.
Axis alignment
Hint:
Selecting items
They can then be grouped:
  • By clicking on the 'Group' icon. File:Panel Icon Group.jpg
Shapes toolbar
File:Panel Toolbar Shapes3D.png
Below it is the 'Text' icon, used to 'drag and drop' a single row of alphanumeric characters onto the work area. Afterwards, you can select it, by clicking on it, and configure it using the Properties Panel. In particular, when added, you can edit the default text displayed using the bottom ‘Text’ control on the Properties panel.
The remaining icons allow you to add a variety of shapes - some two-dimensional, others three-dimensional, to the work area. Each takes the colour chosen in the colour selector at the top. Each one can be configured using the Properties Panel, to determine the position, size and rotation of the shape, for example.
All objects can be dragged between the Dashboard and System panel and dropped in the required position.
Controls toolbar
Moving objects
Component controls
File:Panel Icon Move.jpg The left-hand end control allows you to move the selected object around the work area.
File:Panel Icon Stretch.jpg Moving to the right, the next control allows you to re-position a single point on an item. When you select an object and click on this control, pink anchors appear on the object. Selecting one of these allows it to be moved to a new position on the work area. The effect is to change the appearance, size or rotation of the object.
File:Panel Icon Resize.jpg The next control allows you to change the size of the object. After selecting an object and clicking on this control, a number of blue anchors appear on the object. Any of these can be dragged to re-size that particular dimension of the object. (Handles at the corners affect size in two dimensions.)
File:Panel Icon Rotate.jpg The fourth control allows you to rotate an object. After selecting it and clicking on this control, a number of yellow anchors appear on the object. These allow the object to be rotated around different axes. Corner anchors will spin the object.
Controlling the camera
Camera controls
File:Panel Icon CameraPan.jpg The first allows the camera to pan left / right / up / down.
File:Panel Icon CameraRotate.jpg The second allows the camera to rotate assuming the table top is the ground.
File:Panel Icon CameraOrbit.jpg The third allows the camera to rotate without considering the table top.
General Options
File:Panel Icon Collision.jpg The next control determines what happens when two objects ‘collide‘. The options are that they move through, move around or move over each other, with respect to the camera view.
File:Panel Icon LocalAlign.jpg The next control is used to align the camera with the selected object.
File:Panel Icon Tools.jpg The first allows you to lock movement of objects:
  • To the grid,
  • To other objects,
  • To the table-top
File:Panel Icon GeneralOpts.jpg The second general options dialog is used to:
  • Set the colour or image of the display;
  • Set the number of views, allowing, for example, plan and elevation views of a component;
  • Set the level of detail of all the displays.
Multiple views
By selecting multiple views in the general options several camera angles can be displayed on the same image, enabling orthographic design of the system. Up to four views can be shown.
