API Console.AddText
|   | AddText |
| Adds a window to the list of consoles available | |
|  - STRING | Name |
| The name to appear as the consoles title | |
|  - BOOL | UserWrite |
| Set true to allow input from the User | |
|  - HANDLE | Return |
A text console is a stream of text suitable for use as a terminal to display, for example RS232 data or a remote connection. When text is added, this is always appended to the end of the stream so the text contents will get larger. This differs from the AddMemory call which has a fixed size and operates in 'overwrite' mode to change the text.
Once a handle is created it must be retained, as Flowcode will remove any handles from the system that are not referenced.
The style and content of the console can be changed at any time. The only thing that is fixed is the type of console - a text console always has a variable size and a variable number of characters per line.
- Add to a calculation icon: result = ::Console.AddText("name", true)
Flowchart example
The example  SIMAPI Console illustrates basic creation of a console window.
