Component: Object Helper ( Data)
(Redirected from Component: ID 2e5d477d 7e43 4691 95e1 becf96fed02d)
Jump to navigationJump to search| Author | MatrixTSL |
| Version | 0.1 |
| Category | Data |
Object Helper component
Component to help when dealing with Javascript objects.
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Object.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Object.fcsx
Weather Example
Example program showcasing a number of components used together to collect data from a URL using fetch, before processing the data using the object helper and array helper components.
GetKeys
| GetKeys | |
| Returns a list of the JavaScript object's keys | |
| Object | |
| The JavaSctipt object | |
GetValue
| GetValue | |
| Gets the value for a key in a JavaScript object | |
| Object | |
| The JavaScript object | |
| sKey | |
| The key name | |
JSONToObject
| JSONToObject | |
| Converts a JSON string to a JavaScript object | |
| Text | |
| The JSON string to convert to a JavaScript object | |
NumberToObject
| NumberToObject | |
| Converts a number to a JavaScript object | |
| Var | |
| The number to convert to a JavaSctipt object | |
ObjectToFloat
| ObjectToFloat | |
| Converts an object to a floating point value | |
| Object | |
ObjectToInteger
| ObjectToInteger | |
| Converts an object to an integer | |
| Object | |
ObjectToJSON
| ObjectToJSON | |
| Converts an object to a JSON string | |
| Object | |
ObjectToNumber
| ObjectToNumber | |
| Converts an object to a number | |
| Object | |
ObjectToString
| ObjectToString | |
| Converts an object to a string | |
| Object | |
SetValue
StringToObject
| StringToObject | |
| Converts a string to a JavaScript object | |
| Var | |
| The string to convert to a JavaScript object | |
| Properties |
