Component: Thermistor Template (Sensors)
(Redirected from Component: ID bd7d5205 c2eb 48b1 8a37 f967f349965f)
Jump to navigationJump to search| Author | Matrix |
| Version | 2.0 |
| Category | Sensors |
Thermistor Template component
Base component for creating thermistors. Has no GUI - this would be added by concrete examples using this basem which may or may not expose the propertes.
Version information
Library Version, Component Version, Date, Author, Info 5, 2.0, 19-07-24, BR, Added compatibility for external ADC 5, 2.0, 19-07-24, BR, Allowed full bit depth usage of the internal ADC
This example simply reads the value from the thermistor sensor component and outputs the value to an LCD as a temperature in degrees C.
EBM003 Example
CalculateTemperature
| CalculateTemperature | |
| Converts the input ADC value and returns the Temperature in tenths of degree C | |
| ADCValue | |
| ADC Reading to be converted | |
GetADCValue
| GetADCValue | |
| Returns the Raw ADC value from the Analogue Channel | |
GetIntegerTemperature
| GetIntegerTemperature | |
| Reads the ADC input and returns the calculated Temperature as Integer degrees C | |
GetRealTemperature
| GetRealTemperature | |
| Reads the ADC input and Returns the calculated Temperature as Float value in degrees C | |
SetADCValue
| SetADCValue | |
| Used to set the ADC value when an external ADC is being used. | |
| AdcValue | |
| Value of the external ADC. e.g. 0-255 for an 8-bit ADC | |
SetChannel
| SetChannel | |
| Set the ADC Channel | |
| ChannelID | |
SetTemperature
Please click here to download the component source project: FC_Comp_Source_Thermistor_base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Thermistor_base.fcfx
