Again, after update this afternoon the ILI9341, ili9488 and the ST7796 with ESP32 not working again
Jorgen
Ilidisplay after latest update!
- Has thanked: 510 times
- Been thanked: 132 times
- Has thanked: 522 times
- Been thanked: 477 times
Re: Ilidisplay after latest update!
Hello Jorgen.
We are really sorry, that the latest update breaks things, but they are done for a very good reason.
The updates will cause pins to change.
Can you please change the component pins back to where they were, prior to today's update.
Hi Martin!
I got a chock I have some project with these display and device I still working on, and suddently not working and every time there are a new update I check to see if it still is possible to compile
I change the pin, and on the "highspeed mode" they work again, but I have my most inportan project I made before Ben speed up these display where I use other pinnumber, this will not compile even after have change the pin as before update.
To be sure I have a PC where I still not have perform the latest update I compare all the pin. Please have look.
- NewSun.msg.txt
- (48.31 KiB) Downloaded 115 times
- NewSun.fcfx
- (189.38 KiB) Downloaded 113 times
- Has thanked: 449 times
- Been thanked: 609 times
Many apologies for that, hopefully now fixed for you.
