Jorgen
Ilidisplay after latest update!
jgu1
- Has thanked: 910 times
- Been thanked: 220 times
Again, after update this afternoon the ILI9341, ili9488 and the ST7796 with ESP32 not working again
Jorgen
Jorgen
- Has thanked: 795 times
- Been thanked: 858 times
Re: Ilidisplay after latest update!
Hello Jorgen.
We are really sorry, that the latest update breaks things, but they are done for a very good reason.
The updates will cause pins to change.
Can you please change the component pins back to where they were, prior to today's update.
jgu1
Hi Martin!
I got a chock
I have some project with these display and device I still working on, and suddently not working and every time there are a new update I check to see if it still is possible to compile
I change the pin, and on the "highspeed mode" they work again, but I have my most inportan project I made before Ben speed up these display where I use other pinnumber, this will not compile even after have change the pin as before update.
To be sure I have a PC where I still not have perform the latest update I compare all the pin. Please have look.
I got a chock
- NewSun.msg.txt
- (48.31 KiB) Downloaded 495 times
- NewSun.fcfx
- (189.38 KiB) Downloaded 504 times
- (view online)
- Has thanked: 647 times
- Been thanked: 856 times
