HI ,
I'm trying to control my power supply's trough tcp/ip
I worked it out to control 1 power supply .That program works great . but when I'm trying to connected the other one it all goes wrong .
what i tryed so far:
-every powersuply has it's unique ip adress and its on port .
-do i have to close the port every time i connect to another power supply?
I'm totally new in al the internet things
thanks in advantage for your help guys .
how to connect to different node's trough tcp ip
- Has thanked: 5 times
- Been thanked: 3 times
- power_suply_V_A_P_with_feedback_minderbelasting_TCPIP_keymapping_test_belasting1V2.fcsx
- 2power supply's
- (58.35 KiB) Downloaded 186 times
- Has thanked: 454 times
- Been thanked: 612 times
Re: how to connect to different node's trough tcp ip
Thanks for posting that looks great. Have you tried using a second network comms component to establish the communications with the second device?
Hello BenR
I used another tcp_Ip component but no connection with the load at al . I think this would work if i had multiple network cards in my PC but unfortunately I don't have .
- power_suply_V_A_P_with_feedback_minderbelasting_TCPIP_keymapping_seconde_tcpIP.fcsx
- (54.9 KiB) Downloaded 190 times
hi all
I finaly figuered it out how to connect to different node's trough tcp/ip and make it look "realtime" i start from scratch again .
now every node has +/- 750ms to speak to the main PC that controls everything .
A question to the developers : when i use the timer interupt the given info about the frequentie isn't right ? i had to go on my feeling wich frequentie works for me becaus the highlighte frequentie doesn't match the real frequentie.
- timer_fout.jpg (106.47 KiB) Viewed 4140 times
- realtime_strategieV1.2.fcsx
- why doesn't match the freq given the "real" frequentie"
- (35.24 KiB) Downloaded 192 times
Yes we are aware the simulated timer interrupt rate may be a bit off and one of our major goals for the next version is to try and improve this.
Well done on getting it working though and many thanks for sharing with us.
hi everybody
I encountered next probleme when running the flowchart in simulation my 2ddashboard ended up beining white
the only thing i can do then is close everything en start everything up again
thx again for your help guys
Greetings Ruben
Greetings Ruben
- simulator_V1.4.1_realtime_strategie_tcp_Ip_oké_output_Input_oké_update.fcsx
- (63.79 KiB) Downloaded 184 times
- white_screen.jpg (53.51 KiB) Viewed 4066 times
- Has thanked: 171 times
- Been thanked: 289 times
Hi.
I've tried simulating your program, but I've not been able to replicate the problem. Were you doing something particular when the error occurred or was there any error message reported?
