html save issue
RGV250
Has thanked: 46 times
Been thanked: 46 times
Flowcode v9 html save issue
Post by RGV250 »
I do not know if it is possible to fix this problem, it could be a windows thing.
If I edit a web page (using Notepad++) and then simulate it, run the Flowcode project and then the web page all works fine.
If I then decide to edit the page I get the following warning that it cannot be saved as it may be protected. Stopping the simulation is not enough or closing the open file. I have to close Flowcode completely which is annoying to say the least. Is there anything that can be done to stop this happening.
html save.jpg (20.25 KiB) Viewed 2527 times
Bob
Has thanked: 616 times
Been thanked: 815 times
Re: html save issue
Hi Bob,
Aha yes I know what this is likely to be, I've just pushed a change to the library system that should hopefully solve this issue for you.
RGV250
Re: html save issue
Post by RGV250 »
I have just tried a library update (full database) and it says I am up to date?
Bob
Re: html save issue
Hi Bob,
Aha I fixed it in v10, are you using v9?
I'll get it sorted in v9 for you too.
RGV250
Re: html save issue
Post by RGV250 »
I am using V9 currently but plan to go to V10, probably at the end of the month when I get paid again. (thats the problem when you take early retirement).
Bob
RGV250
Re: html save issue
Post by RGV250 »
Thanks, it works fine, dont even have to stop the simulation.
Bob
