Hi Guys!
I can't seem to set up the UartSoftwareTimer component either. Transmit buffer Size and Receive buffer Size are not changed, I can't change their value. by default Transmit buffer Size and Receive buffer Size 50.
this component also does not work if you enable TX and RX
UartSoftwareTimer component FC9 Help
d820513
- Has thanked: 2 times
- Been thanked: 1 time
Re: UartSoftwareTimer component FC9 Help
here is the project
- uart_timer.jpg (81.77 KiB) Viewed 1570 times
- test_send_char.fcfx
- (10.81 KiB) Downloaded 214 times
- Has thanked: 724 times
- Been thanked: 783 times
I have set up the timer UART for 38400 baud on the Arduino UNO.
As the timers are not good on AVR devices, I decided to use the Timer Interval component, to save a lot of calculation and C code within a custom interrupt.
You will need to make some adjustments to the Time Period value within the Timer Interval component. so it may be a little trial and error, but with a logic analyser it was a very quick process.
I have added instructions to the project file.
Here are the end results of incrementing a number at a baud of 38400:
- Send UART 38400 FC9 Uno.fcfx
- (13.75 KiB) Downloaded 206 times
