LCD_SSD1351 FC8 FC9 not compatible
Has thanked: 246 times
Been thanked: 258 times
LCD_SSD1351 is working FC8
But FC9 not compatible with F8, how the text is on the display. Some text is turned 90 deegres and fonts are different
And the propertis looks new in FC9
Do you have some infos?
Has thanked: 647 times
Been thanked: 856 times
Re: LCD_SSD1351 FC8 FC9 not compatible
Can you please post your program and I will have a look for you.
Regarding the v9 gLCD fonts this post might help.
viewtopic.php?p=81#p81
In the simulation the Text and the line turning around. In the hardware is just the line is turning, the text is always in the same direction.
emg_empty.fcfx
(87.41 KiB) Downloaded 1193 times
Hi Stefan,
Great really appreciate that and thanks for letting me know, hopefully solved for you now.
Thanks a lot. It's working now in all the directions.
But there is a little problem when I set the display orientation to 3, the clear display command is not working anymore.(in all the another orientation the clear display command is working)
unfortunately I use the display in orientation 3
Thanks Stefan,
Should be sorted for you now.
Perfect ! And the new font's looks good.
