time runs very fast
Vatel20
time runs very fast
time runs very fast in the version 8 and version 9
- TestTimer.fcfx
- (13.03 KiB) Downloaded 550 times
- (view online)
- p.erasmus
- Has thanked: 104 times
- Been thanked: 88 times
Re: time runs very fast
When is it running to fast in simulation or Hardware
looking at your flowchart the Timer interrupt is set at a very fast rate may be you should do some adjustments
Sorry I do not know how it happened. I send the correct setting. but the result is the same. What I understand is that every clock cycle interrupt.
- Int.png (21.9 KiB) Viewed 5681 times
- Has thanked: 794 times
- Been thanked: 858 times
It depends if you are referring to simulation or hardware.
If simulation then it will run fast and I can help you further with that.
If hardware then if you post your flowchart then I can see if I can help you further.
