App Developer freezing [Resolved, not freezing]
Has thanked: 794 times
Been thanked: 858 times
Within Export menu.
Save the current 2D Dashboard Panel as image causes App Developer to freeze.
Has thanked: 311 times
Been thanked: 479 times
Re: App Developer freezing
Thanks, Martin.
I've tried to replicate and it appears to be working fine for me. Is it with a specific project or component? Please post or PM with the project you are having the issue with and I will try to fix.
Hi Steve,
Thanks for your reply.
It's the Component Tester found here
I've tried with that project and all export formats work, but the "mesh" export takes a very long time. I cannot replicate Flowcode freezing. Was there a specific image format that causes the freeze for you?
All image file formats are exported quickly, but they do not show the image (this is a known issue with some of the objects on the 2d panel - e.g. charts, gauges).
Hi Steve, thanks.
I have just tried again and been more patient.
After 4 minutes on my PC, App Developer still not responding, hence thinking its freezing.
It took 6 minutes and indeed not freezing but a very long time like you suggested.
Re: App Developer freezing [Resolved, not freezing]
Thanks, Martin.
So you are aware, I've rearranged the file formats when saving an image so that the "mesh" is last (and "png" is the default).
Has thanked: 246 times
Been thanked: 258 times
Hi Martin
I wanted to import a simple 3D object into the App Developer (just a cube).
It had also taken several minutes. Flowcode was like frozen.
Has thanked: 647 times
Been thanked: 856 times
When importing an object flowcode pops up a window with the import properties. This window often appears behind the main Flowcode window and so it looks like Flowcode has crashed displaying Please Wait.
Yes I have see that and threw me the fist time.
It was as Ben suggested.
The pop up window was behind Main Window.
As soon as I spotted that, it was all good.
