LM75B macro error
niedian
- Has thanked: 3 times
- Been thanked: 5 times
- Has thanked: 725 times
- Been thanked: 783 times
Re: LM75B macro error
Hello, thank you for letting us know.
I have fixed the component and will be pushed onto the update system as soon as possible.
If you would like to try the component before the updates are pushed.
Replace the existing files with the attached files.
If you run any component updates, then the components you added will be overwritten
C:\ProgramData\MatrixTSL\FlowcodeV10\ComponentsIf Flowcode is already open, then you will need to reload your project for the new components to work
- EBM004_DigitalTemperature.fcpx
- (4.55 KiB) Downloaded 236 times
- LM75B_DigitalTemperature.fcpx
- (4.57 KiB) Downloaded 253 times
I can confirm the updated component has been pushed onto the update system.
If you run a component update The component I posted will be replaced with the latest version.
