LM75B macro error
niedian
Has thanked: 3 times
Been thanked: 5 times
LM75B macro error
Post by niedian »
IN V10,LM75B macro error,simulation keeps showing 0.
LM75B macro error.fcfx
(11.62 KiB) Downloaded 305 times
Has thanked: 795 times
Been thanked: 858 times
Re: LM75B macro error
Hello, thank you for letting us know.
I have fixed the component and will be pushed onto the update system as soon as possible.
If you would like to try the component before the updates are pushed.
Browse to this location using file explorer, it's hidden by default so just paste the link into your address bar.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
Replace the existing files with the attached files.
If you run any component updates, then the components you added will be overwritten
EBM004_DigitalTemperature.fcpx
(4.55 KiB) Downloaded 249 times
LM75B_DigitalTemperature.fcpx
(4.57 KiB) Downloaded 267 times
I can confirm the updated component has been pushed onto the update system.
If you run a component update The component I posted will be replaced with the latest version.
