I'm working on a CAN Bus communication with eblock2 but I've been having several issues and they are listed below
1 : recognition of the ardruino port and bl0055 eblock2 usb on my pc device manager : I found the link below on how to set it up but after downloading the drivers, I couldn't find on my device manager
https://www.matrixtsl.com/faqx/index.ph ... artlang=en
2. How to upload each programs on each CAN nodes using flowcode
Interfacing flowcode program on adruino BL0055 eblock2 board
Oluwatobiloba0000
- Has thanked: 1 time
- 20221018_110924.jpg (181.01 KiB) Viewed 14340 times
- Has thanked: 800 times
- Been thanked: 866 times
Re: Interfacing flowcode program on adruino BL0055 eblock2 board
With only the Arduino Uno connected to the PC via USB
If you select Build > Project options, you should have something like this:
Oluwatobiloba0000
From the device manager. The USB isn't recognised as it can be seen in the picture attached to this message. Does it matter? How do I go about it if it matters. Thanks
- Screenshot_20230316_153210_Gallery.jpg (28.42 KiB) Viewed 14318 times
Yes, it's vital that when you plug in the Arduino, a VCP (Virtual Com Port) is automatically set up like this: For that to happen you must have the correct drivers installed.
Some Uno's will work straight away as windows will have the correct drivers by default e.g. Dip version
For other Uno's e.g the SMD version, you will have to manually add the drivers.
I believe it's the CH340 drivers.
I have attached the drivers for you to try.
- CH341SER.ZIP
- (545.38 KiB) Downloaded 1093 times
Oluwatobiloba0000
From the given example on the can training material like the braking system, how can I navigate through the project manager to see how each connection is made with the eblocks(nodes), how the pins are selected and the variables to be able to relate all that with the flowchart.
- Has thanked: 650 times
- Been thanked: 856 times
You probably want the properties window, using the drop down list at the top of the properties window you can select the various components in the project and look at their properties such as pin connections.
Oluwatobiloba0000
Node 1= lcd( dashboard display)
Node 2 = switch(brake)
Node 3= led( brake light)
Node 4= sensor
Using these nodes to carry out a simple project where when the switch is pressed, the led turns on and also the lcd to display 'brake ON' and also the fuel gauge level when the potentiometer is tuned..
1. How do I go about the CAN ID number, message IDs,
TX and RX buffer
2. How to set masks and filters
3. How to go about configuration of each nodes
Node 4= sensor
TX and RX buffer
This document should have all the information you need.
https://www.flowcode.co.uk/old_site/res ... %20Bus.pdf
Firmware projects mentioned in the document are available here.
https://www.flowcode.co.uk/old_site/res ... 0Files.zip
If your still having problems with your Arduino driver then you can install the device driver that is included with the Flowcode installation. Just right click the device in device manager and select install device driver, then select from known location. The location will probably be something like this C:\Program Files (x86)\Flowcode 9\data\Drivers\Arduino
Oluwatobiloba0000
I understand the examples given in the training course code. I would just appreciate the total break down of how the can properties configuration of each node is made and how each node flowchart is programmed. Let's use an elevator system for an example. The switch node will be for the number of floors, lcd node will be for the screen monitor for the floor number and also the Led node will denote the floor number. Switch 0 will be used as the door opener. A video will be helpful if it is possible. Thanks
